? about the GT500 splitter
#42
RE: ? about the GT500 splitter
ORIGINAL: Boozshey
Also I just realized why you guys are getting sag. You have to bolt the sides deep into the wheelwells. In doing so it cause the center section to turn up and sit flush and not sag...
When you're are installing it you will have to pull it in, you will feel it resist, but that just means its pulling it up and not sagging.
#43
ok so you cant just screw them into the oem slots? i just picked mine up today guys for 75 plus tax, and im gonna put it on after work tonight, please someone do a quick write up or something so we all know how to properly install it, the sag is no big deal as there are ways to fix it, but i need to get this thing up and ready for panama city beach next week this will help a lot
#44
ORIGINAL: Xeno
[/align][/align]I understand what you mean, but I actually did that (I bolted it in 3 places on each side actually) and it still sags . I think I know how to fix the sag now, but I would have to drill more holes and you would see the bolts afterwords, though.[/align][/align]Actually, where you have the splitter screwed into the bumper is closer to the center of the car than mine; maybe thats whats causing the problem (mine is screwed into the spot where the oem screw is (the one to the left of where you screwed the splitter on))[/align]
You have to pull it more into the middle of the car, like I was trying to explain...
#45
http://forums.stangnet.com/738399-gt...lation-gt.html
This is the only how-to that I could find since the search function on here is down.
The only two things that I would recommend different however. Is to not cut the entire section out. Only the crossbeam pattern in the same spot. Just like the pictures I posted earlier.
The second thing I would do different is, that I wouldn't use the factory spots as I have posted just recently.
#46
(I figured it out as I was writing my last post and forgot to erase the first part of what I said [&:])
