Sponsored by:
Sponsored by:
X or H?
Old 05-21-2009, 10:18 AM
  #61
vasman
vasman's Avatar
Exclamation Issue with Singers after LT install
One minor issue we both have experienced with the stingers is that on the driver side, one of the exhaust hangers (the longest one) is rubbing against inside of the fender generating a lot of rattling on occasion.
You may be able to pull the whole catback system forward at the point where the H (or X) pipe connects or simply shorten the hanger by cutting it.
I will attempt to cut it without removing the exhaust and report. Trigger06 reported success by just pulling it forward as described above, but I have a feeling that mine will not work as well.
vasman is offline
Old 05-21-2009, 04:46 PM
  #62
bolivianpimp
bolivianpimp's Avatar
Vasman you are in the woodlands right? I am too, think i could meet up with you sometime to hear your car?
bolivianpimp is offline
Old 05-22-2009, 03:38 AM
  #63
07 GT E UPP
07 GT E UPP's Avatar
Originally Posted by vasman
Thanks bro Indeed sounds great. I am thinking putting the comp thumpers with the limiters. But will wait till the end of the summer.
Great to hear...... Yep,Thumpers will certainly sound amazing also...!!
And...Oh Ya, let's not forget the additional 30 HP !!
07 GT E UPP is offline
Old 05-22-2009, 09:37 AM
  #64
vasman
vasman's Avatar
Fixed the issue the same way trigger06 did. Now I have an inch clearance. even with expansion it does not get closer that 1/4 of inch from the fender, so I will try it this way for now. So far so good.
vasman is offline
