X or H?
Old Apr 23, 2009 | 10:43 AM
vasman's Avatar
vasman
Question X or H?
I have an 07 gt with Borlas axle backs.
I am considering the kooks headers with hi flow cats. Do you recommend the X or H pipe for my configuration? My mid pipe is stock (between the borlas and Cats).
I am thinking of self install if that is a factor. I am also thinking of putting a mild set of cams (comp stage 2 NSR's)
Thanks in advance.
Old Apr 23, 2009 | 11:32 AM
Shelby_Daytona's Avatar
Shelby_Daytona
My setup is different than yours but I will chime in with my findings, I had a 3" Magnaflow Cat-back that sounded pretty good, at lower RPMs, I put in a Bassani Catted X-pipe last week and WOW what a difference, the sound is way way better, the drone is way less, and it sounds WAY better at all RPMs especially higher... 3500+ is amazing... and from what I hear without the Cats it will sound worse..
From what I've gathered, shorty headers are a waste of time, there is a slight gain from long tubes but hard to say if the pain in the *** of swapping them out is worth it, I suggest a high flow catted x, stock midpipes, as they arent too much different than the aftermarket exhast if you are staying at 2.5".... bolted to your axlebacks... I think it would sound good then, but that is just my suggestion, to each their own. That way you are only swapping out the X...
Old Apr 23, 2009 | 12:46 PM
07 GT E UPP's Avatar
07 GT E UPP
Thanks in advance.
Well vasman, I'm kinda partial here as you will well see in my Signature.....IMO, definately an H-pipe with High-flow cats with what you have, and are thinking of doing. Mine sound amazing... !!
Old Apr 23, 2009 | 01:38 PM
vasman's Avatar
vasman
Thanks. I kinda thought that the H was the way to go, but I had fastlane in Houston pushing the X's on my car for some reason. They claim more hp gain in the region of 5-7hp vs H pipe.. Did you see any power gain with the Kooks LT's and the hi flow cats?
Old Apr 23, 2009 | 01:44 PM
S197GT07's Avatar
S197GT07
Def go with the H pipe, and then post sound clips because that is exactly the same exahust that I want.
From a few other threads of people installing long tubes they said you will loose a little low end torque, but gain alot up top.
Old Apr 23, 2009 | 01:56 PM
zporta's Avatar
zporta
I would say an H... deeper tone...
Old Apr 23, 2009 | 02:06 PM
zkiller's Avatar
zkiller
X-pipe will definately have a gain over the H-pipe as it scavenges the exhaust pulses better. H-pipe has a deeper sound in most cases.
Old Apr 23, 2009 | 02:08 PM
bolivianpimp's Avatar
bolivianpimp
Hey im here in houston also. I have not heard an X in person, but I really like my offroad H. I do not have headers, but I've heard that the H will make it sound throatier and deeper , while the X will make it a little louder but raspier. Either way, I want to hear your stuff in person! What part of houston are you in?
Old Apr 23, 2009 | 02:17 PM
smokestang's Avatar
smokestang
H-pipe with borla all the way! H = deep and throaty.
Old Apr 23, 2009 | 02:36 PM
vasman's Avatar
vasman
woodlands
