Sponsored by:
Sponsored by:
'07 door drain issue....
Old 06-27-2009, 11:38 PM
Alphy07
Alphy07's Avatar
Default '07 door drain issue....
Hi guys, first post here.
I picked up an '07 GT the other month. I have noticed that after I wash or if it sits out in the rain that when I open the drivers door that there is water laying on top the mustang sil plate.
I see that water is coming out the bottom of the interior door cover(which is to the inside of the door seal), which im sure its not suppose to. I also notice small black 'clip' looking things to the front and rear of the very bottom of the door which cover hole's in the door. Im assuming that either thats where the water is suppose to drain out the door or the window seal(or some seal) shouldnt be letting the water into the door?
Thanks for any help, and I hope this is the correct place for this thread
Alphy07 is offline
Old 06-28-2009, 10:24 AM
smokestang
smokestang's Avatar
Ive noticed the same thing on mine! i always dry the inside of the door sill everytime i wash the car. not sure what the purpose of the black tabs are though.
smokestang is offline
Old 06-28-2009, 11:19 AM
Alphy07
Alphy07's Avatar
Did some searching on here and I think I found the issue:
https://mustangforums.com/forum/2005...or-anyone.html
https://mustangforums.com/forum/5300951-post5.html
https://mustangforums.com/forum/2005...door-sill.html
I cant believe that the black plugs themselves would restrict flow that much so I figured I had enough gunk built up in there that it was blocking things. I had taken the plugs out previously and there was debris behind them, so i figured thats the issue. I went out, removed the plugs and used a dental pick to fish around and remove any gunk. Interestingly enough I didnt get much out. So either I have a blockage further up in the door(which doesnt look possible due to how the door design looks) or these plastic plugs actually did hinder water drainage THAT much. We'll see.
Alphy07 is offline
Old 06-28-2009, 07:27 PM
Nuke
Nuke's Avatar
There is also a good bit of water that sits in the rubber seal around the door at the bottom. If you gently roll back the rubber just a bit after a wash the car you'll get some water out from the bottom of the door. It's not the only source of this water but it is a contributor.
Nuke is offline
Old 06-30-2009, 09:46 AM
Alphy07
Alphy07's Avatar
So i took my plugs out and got any debris out of the slots. Water is still coming out from behind the interior door panel instead of the drain holes.
Guess ill have to try to find instructions on removing the door panel to have a look, or drop it off at the dealer
Alphy07 is offline
Old 07-01-2009, 10:22 AM
mmdpg
mmdpg's Avatar
I had the same issue. Remove the door panel and you will see the vapor shield is probably not sealed all the way around. Buy the same soft, non-hardening sealer and fill the openings in the shield to door mating surfaces. This will prevent most of the water from getting to the door panel and it will drain out the holes instead. I also removed those little plugs and left them off.
mmdpg is offline
Old 07-01-2009, 11:43 AM
8178A
8178A's Avatar
My 07 had that problem and the local Ford Dealer said it was not fixable. I took it to Ford Dearborn and they said that water on the door sill is normal and there is NO fix. My 09 door seal looks the same as my 07 but it doesn’t do it.
8178A is offline
Old 07-01-2009, 03:35 PM
157dB
Cut & Paste Expert
157dB's Avatar
Its normal.
The door sill is considered to be outside of the watertight (yea, right)
passenger compartment. The water is coming in thru between the glass
and the rubber window trim on the door.
It then travels down thru the inside of the door and out of drains in the bottom
of the door. Clogged drains causes a wave sound in the door while taking off
or stopping.
Sounds like someone upgraded the door speakers and trashed the plastic water barrier.
Your doors internal electrics wont like you for this.
It all needs to be there like OEM or water will come out from inbetween the door panel
and the door sheetmetal on the inside of the vehicle in an area deemed 'watertight'
by Ford.
There are two rubber seals. The inner one is to keep water out of the passenger
compartment and the other is to keep the door sill partially clean?
157dB is offline
Old 07-02-2009, 12:10 AM
doode
doode's Avatar
mine is on tight
how is water supposed to be draining from it ?
doode is offline
Old 07-02-2009, 05:54 AM
GT John
GT John's Avatar
Yeah, those black plastic things need to be removed. If not water will be trapped in the door and eventually the bottom of the door will rust out.
I had to remove mine when I first bought the car. There are two on each door.
GT John is offline
Quick Reply: '07 door drain issue....
