Please help with noises all over the car!
my rattling began ever since i installed my longtube headers. Once i finally had all the rubbing issues fixed these issues began........
*loud clunk(in the rear) began to happen sometimes when i either start the car, close the door of the car, or hop into the car when the car is cold.
*popping sound when i turn the wheel getting into and out of parking spots(only issue that occurred before LT install)
*swooshing sound whenever i step on the gas from a stop sounding like its coming from my auto tranny.
*crazy weird whirling/high pitch/sqeaky sound coming from my driver side rear......
All this adds up to me absolutely HATING driving my car.....i dont even know how to begin to fix these problems.... If anyone has any advice, i would really appreciate the input.
BTW i have Spohn LCAs and adjustable panhard bar, pro kit, and d specs if it matters.
The whoosh sound you hear when stepping on the gas is probably a cold air intake if you have one. The whirling noise is most likely gear whine. I didnt notice mine until i changed my control arms out and i have poly bushings. I imagine that with a rod end or two that the gear noise would be unbearable.
Also the whirling sound shouldnt be gear whine because i have not changed my gears and it happens when i go over bumps..
grab the long tube header piping and shake it around hard. That may isolate the header clunking.
the popping sounds like a tsb issue
Check the midpipe and mufflers to see they are not loose or anything either.
The popping sound when turning the wheel is probably the tie rods.
I had that problem before, had them replaced under warranty.
I don't know if this is relevant, but after installing my Kooks, the whole exhaust system is hanging so low now that scrapes at places where it did not scrape before the headers. And my driver's side over axle pipe is rubbing against the panhard brace causing an annoying rattle. But I'm getting it all fixed tomorrow at a custom exhaust shop.
I got under the car and took a rubber mallet and banged the entire exhaust and could not even get a rattle...... I am started to think it has something to do with my suspension in the rear because it doesnt sound anything like exhaust pipes hitting.
The exhaust hangers might be rubbing against the sheet metal. Even though you could see that they don't touch when the car is stopped, they tend to hit the bumper from the inside when going over bumps.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Daleford
08-10-2015 08:30 PM
