HOW QUARTS OF OIL DOES 07 MUSTANG GT TAKE?
It should be six quarts on a GT. Are you also changing the oil filter? If you change the oil but not the filter, some oil will remain in the filter. Are you running the car so that the oil circulates and then waiting a few minutes for it to drain into the pan? Do you have the correct oil dipstick?
Yeah, i am changing the oil filter also. It'd be kinda dumb not too huh??? Either way, I buy a 5 quart jug of Mobil 1 + 1 quart and there is always about half that quart left over. Who knows? Maybe ford gave me a deformed oil pan
It can vary with how level (or not) your car is when you drain plus the jugs from the stores can vary slightly from exactly a quart or whatever the value is for the container. Don't sweat a 1/2 quart or so diff between owners. Just as long as you're between the upper and lower marks on the dipstick.
Remember to pre-fill those oil filters
to avoid a dry start-up while the filter fills with oil...
