Sponsored by:
Sponsored by:
Headlight Switch Bulb
Old 06-03-2012, 07:35 PM
  #71
warment
warment's Avatar
Acdelco bulb/socket worked. Not quite as bright as the stockee though...the Acdelco bulb/socket is a little shorter.
warment is offline
Old 01-14-2016, 02:25 PM
  #72
randyre
randyre's Avatar
Default Found LED replacement
I know this is an old post, but its relevant and I'm sure many people use it as a guide to fix this issue, so I thought I'd up date it.
Found a LED based bulb and as of Jan 2016 its only $2.40 shipped for two of them, this includes the LED and Neowedge base.
http://www.wardenjp.com/stores/neowedge.html
The other option is a pre-wired SMD LED.
http://www.ebay.com/itm/0603-SMD-LED-10pcs-Pre-soldered-Micro-Litz-Wire-BLUE-RESISTORS-3V-12V-small/231726815468?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35006%26meid%3D3844354e244d4a25a97929a7f075e176%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D231743402902
randyre is offline
Old 01-15-2016, 09:29 PM
  #73
akdoggie
akdoggie's Avatar
That is funny. I ran across the site a couple weeks ago and just got in the bulbs today. They are quite brite. I went with the t3 for the size. I will pull the switch this week and make sure that is the correct size. The new bulbs match the GM bulbs I pulled the other day from a Buick digital cluster I pieced out. These were in great shape (3), so i'll have those in reserve, if these new bulbs mess up. The maximum length of these isn't as deep as the factory bulbs, but I'm hoping that with the strong power of the LED, will give off enough power to light the emblem significantly.
Great find for not too much money. Thumbs up to you.
akdoggie is offline
Old 01-15-2016, 10:22 PM
  #74
Goldenpony
Goldenpony's Avatar
You can see my post on page #6. I got bulbs from an online site called Bulbster. The bulb # is 7219. Put this one in 5 years ago or so and it is still working.
Goldenpony is offline
lincolnshibuya
07-05-2020 03:05 AM
PaulH2
20
01-31-2016 09:48 AM
lincolnshibuya
12-08-2015 04:37 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: Headlight Switch Bulb
