Sponsored by:
Sponsored by:
Aeroforce Interceptor Gauge Question
Old 03-09-2010, 05:25 PM
  #21
BruceH
BruceH's Avatar
Originally Posted by candymanjl
rather than make a new topic about the gauge I'll ask you guys
I'm getting ready to buy one of these, will it read PSI without adding a sensor? manifold PSI is listed in the parameters but I don't know if that's only on the factory boosted Fords or all Fords.
thanks!
Doesn't with mine. I'm using a 2 bar GM sensor.
BruceH is offline
Old 03-09-2010, 05:29 PM
  #22
candymanjl
candymanjl's Avatar
I looked on their forums and it implied that I wouldn't see boost. I guess that parameter is only available to the 03-04 cobras and GT500's.
I bought dual gauge with the 3.5 bar sensor since in theory one day I'll run more than 15psi when I build the motor. I also ordered the wideband O2 kit so I can have an accurate signal to look at.
candymanjl is offline
Old 03-10-2010, 07:18 AM
  #23
top00cat
top00cat's Avatar
Does the aeroforce interceptor read air fuel ratio? i was considering getting a wideband but this may be a better route to go
top00cat is offline
Old 03-10-2010, 10:22 AM
  #24
Wes_T
Wes_T's Avatar
The Interceptor will NOT read Air/Fuel out of the box, you'll have to buy an additional sensor kit for it
http://www.aeroforcetech.com/products_sensors.html
It does read manifold pressure out of the box.
Wes_T is offline
Old 03-10-2010, 07:32 PM
  #25
candymanjl
candymanjl's Avatar
yup, I ordered that kit. stock the car doesn't have a wideband O2 anyway so you would never want to go by that.
Galactic
04-29-2019 02:56 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Aeroforce Interceptor Gauge Question
