Sponsored by:
Sponsored by:
Amazing Craigslist deal, I need opinions!
Old 02-27-2010, 03:51 PM
Cal26Stang
Cal26Stang's Avatar
Default Amazing Craigslist deal, I need opinions!
Guys, I was looking on craigslist like I do everyday, and I cam across a couple ridiculous deals from the same guy. The question is what should I buy first and will these cams work in my mostly stock 07 gt
first, he has a pair of adjustable tokico d-specs with the tuning key, they only have 5k miles on them...(owner switched to coil overs)
also, what I really want! he has a set of comp cams
heres the link....
http://kansascity.craigslist.org/pts/1618873354.html
I have a mostly stock motor, just a diablosport tuner, will these cams work in my car? You guys are super helpful, thanks for any advice
Cal26Stang is offline
Old 02-27-2010, 07:20 PM
ejanderson05gt
ejanderson05gt's Avatar
I'm no expert on cams, but these are blower grind cams, meaning they'll benefit you way more if you have a blower. It's a great deal for someone with a blower, but I don't think you'll see nearly the gain on a N/A car.
From Brenspeed's site, "STAGE 2-Mid to upper range cam for bolt-on blowers with high boost. Noticeable idle, solid power gains above 4900 rpm, requires spring upgrade. Best with 3000+ stall."
Eric
ejanderson05gt is offline
Old 02-27-2010, 08:18 PM
Cal26Stang
Cal26Stang's Avatar
keep in mind i want to go prochargered latter, so for 250? w/spring?
Old 02-27-2010, 08:41 PM
ejanderson05gt
If you plan on going F/I, then it sounds like a hell of a deal to me. If it were me, though, I'd probably just buy the cams/springs and hold onto them for a while, get them installed with your blower. That's a great deal, don't let it pass you by if you're sure you're going F/I.
Eric
Old 02-27-2010, 10:42 PM
Cal26Stang
Cal26Stang's Avatar
will i be able to run my car the way it is and then install them? I'm trying to get a custom tune thrown in as well
c'mon guys!!
Old 02-27-2010, 11:44 PM
SirKnightTG
SirKnightTG's Avatar
Running blower cams while N/A is not going to hurt anything. You'll still see some good gains and have a better sound. EagleStroker's cams are blower grinds and he's at 400 rwhp N/A.
SirKnightTG is offline
Old 02-28-2010, 02:10 AM
brad281
brad281's Avatar
I'd look to get them for that good price and try to re-sell them. I wouldn't use them without a modified tune from what you have now.
brad281 is offline
Old 02-28-2010, 11:03 AM
ejanderson05gt
Don't get me wrong, I didn't mean to lead you to believe that blower grinds are not beneficial at all. Like SirKnight said, you'll definitely benefit from the cams, but not necessarily as much as you would with N/A designed cams. Once you go F/I, that's where the blower grind cams will really shine.
Regardless, a custom tune is necessary.
Eric
Old 02-28-2010, 05:10 PM
Cal26Stang
Cal26Stang's Avatar
Good call, that's what I needed, thanks guys
69mach1377
03-10-2017 08:45 AM
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
Suree_Mustang_2009
09-25-2015 12:58 PM
mustangchef
09-04-2015 08:08 PM
Quick Reply: Amazing Craigslist deal, I need opinions!
