the rod from from the brake pedal to master cylinder is causing the squeaking. hard to lubricate without loosening from the firewall, mine does when high humidity. not all the time.
I was annoyed with this issue for a while too. Tried lubricating the bits under the dash to no avail. Ended up changing the brake fluid fixed the issue. Been fine for a long time now.
Thanks! I've noticed on warmer days I get this when I deliver pizza. Hope this will work on mine too.
God bless!!!
