Shaker 500, aftermarket HU, and steering wheel questions
#21
JD I respect your knowledge but you are making this harder than it is. You CAN make your own harness, with resistor for the amp, without spending $100+ on the PAC harness. If you are a person that likes convenience, by all means. If you don't have the know-how to build the harness correctly, by all means. Otherwise, save yourself some money.
Also, to be done right you should use a voltage regulator, not a resistor. The regulator has a pretty broad range where it will retain a constant 5v, where as the resistor just creates a voltage divider circuit and will let any fluctuation in voltage run straight to the amps.
My 08 had the 3rd plug and it was just a stock 500 shaker unit I replaced. I used the pac harness and it was all plug and play....worked like a charm. No popping at startup and all the factory amps/subs seem to be working properly.
I f"in lose it sometimes when guys spend hundreds of dollars on a unit, and then try and skimp out on a cheap harness to wire it up!
You are tripping over dollars to get to pennies doing this with the time and trouble it saves you with the install.
PAC harness wired to the aftermarket harness, ready to install. The little black box is the control module that makes it all function properly...without it, problems will likely occur. Good luck with the install.
#22
My "save money" comment was based on the need of an ignition power only, and the non-needed module assuming the car had C-Bus. If I needed more, I would tell the customer he would come out cheaper to buy the module. Five minutes to tap an extra wire for switched power isn't a big deal when I can transfer minimal (versus the module) money to labor instead of selling a module they really don't need.
Again, you can go ahead and learn or keep pushing OEM NAV only. I already told you, I have personaly installed both. One Shake radio required the harness, one did not. See the above quoted person here, mayo also put in a shaker that was interfaced.
#23
#24
No resistor installed, and no popping...must have done something right...lol. I believe the control module stepped down the voltage to 5v.
Yes, I did have factory sat radio and it was the one snag I did run into with the install. When I first hooked it all up, I noticed at low volume a sat radio signal coming through the head. I just unplugged the factory sat ant under the trunk and it was gone. This could be a problem for someone who subscribes to this service...me not a problem, my ipod is loaded
Plenty of tunes for a sing a long
#25
#26
The regular Metra harness I have had an illumination wire built in, so I'm not sure why it would be there if the stock harness it's plugging into didn't have one. I'm not for sure because I didn't hook that wire up...I don't like the dimming feature.
#27
the metra wires into the aftermarket radio and is for multiple vehicles and years. Some vehicles it is for must have the ilumination but it is pretty well documented with ours.
http://www.allfordmustangs.com/forum...er-1000-a.html
just the first one i found when I googled it, but I know we have thread about it on our forums as well. If you dont care about it then it makes sense that you never bothered to make it work. I have mine enables cause it just annoys the crap out of me when its blinding.
