Moroso Oil Catch Can install with Pics
#22
..and, if you are not SG....it would be pasted all over your intake ports - the brown chocolate stuff, if you ever take off the intake.
#23
#24
Oh wow, I never knew that oil accumulation was of such epic proportions! I really think I need one asap with as much as I drive.
#25
Did you see all that oil in the plastic can...it would be sprayed all over your inter-cooler, reducing the cooling capacity and thus resulting in sub-performance of the blower....
#26
Is there anyone with a 2010 GT and the M90 who is running a catch can? The intake is on the drivers side with mine rather than the passenger side as it looks in the pictures I've seen on the 05-09's. Im waiting to hear back from AM on any recommendation they might have for my situation.
#27
I had previously done this for my 06 GT: https://mustangforums.com/forum/6577234-post466.html
It looked nice, but after this weekend I am considering burning my engineering degrees and thinking about a career change.
The barb fitting on the valve cover cracked. I really underestimated how much it would be loaded with that very short hose and little stress relief. It's not all bad because now I get to buy new FRPP valve covers.
Another problem I created was using the Earl's tubing adapters to permanently convert the barb fittings into AN threads ... they don't come off, which is not a problem on the valve cover but the plastic intake manifold barb is a problem.
I ordered this Moroso separator based on this post, so thanks. Now I just have to figure out how to get that 10AN male thread down to a 1/2" ****** fitting. I'm thinking a 10AN to 8AN reducer and then a 8AN to 1/2" bard.
I wish this setup was available when I decided to do my setup.
#28
OUCH. That plain sucks. Roush responded to my query and said get in touch with blow by racing but that a catch can is not a requirement. I'm planning on using something that is mounted (to alleviate the very stresses you had an issue with) and utilizes OEM fittings.
#29
My original setup was mounted to my heat shield (like most other people) I am almost positive the problem was my short hose. It really needed to be longer to allow for some hose flexibility or slightly shorter with a angled fitting. I had to bend the hose to get the fitting on the separator and the fitting on the valve cover to line up. I think this would actually have fixed my problem, but I was to lazy to order a new hose end fitting and shorten the existing hose slightly. Live and learn, I guess.
On the bright side, my wife was unquestioning of my need to buy new valve covers.
I really hope I can make something work on the intake manifold fitting. My friends think I should just cut through the AN adapter and hope I can still use the OEM fitting. If I damage the tube I could probably cut it off and attach my own with a strong adhesive. The wife accepted the valve covers, but she will probably not be as understanding if I "need" to buy a $700 intake manifold.
I think this Moroso can will work for you. They also sell just the can and bracket. You could make your own mounting bracket and get the fittings and hose yourself. Good luck.
