Moroso Oil Catch Can install with Pics
#32
I used the original return line that was on the engine...works great! It's a bitch to get the hose on to it btw...never got mine all the on, but it's never coming off!
#34
Oil vapor is forced out of the cylinder head and redirected through vacuum hoses into the intake stream. The oil vapor then condenses onto the inside surfaces in the intake system. This is especially prominent in the inter-cooler core. A thin film of oil coating the inside of the inter-cooler will insulate the air to air exchange and lower the ability of the inter-cooler to cool the intake air charge.
Done...
Done...
#35
I bought the Steeda piece, which frankly, was disappointing. Works like it should I suppose, but it was $80 for a very cheap unit (and by cheap, I mean the cost of goods for them could not have been more than $15). Everything was plastic.
Nevertheless, an oil separator is a good idea. Watch the hoses that you are using, since they can apparently collapse if they are put under a lot of pressure in an FI car.
