Sponsored by:
Sponsored by:
M90 roush supercharger pulley removal
Old 02-06-2011, 01:54 AM
fredlo69
fredlo69's Avatar
Default M90 roush supercharger pulley removal
Anyone in NYC who can rent me this tool ( M90 pulley removal tool )
Press on pulley.
Going VMP 500 need tool for swap.
fredlo69 is offline
Old 02-06-2011, 10:13 AM
case ace
case ace's Avatar
Fred, I have no answer for your question, but would be interested in hearing your results when you change pulleys. I am toying with that idea for my M90 also but am concerned about the tune being a little too aggressive and not as "reliable" as the more conservative ROUSH tune. My performance guy here in Chicago has that tool, maybe you could try looking at those places first. Will be looking forward to your results. Have you got the dyno numbers for your M90 now so you can compare?
case ace is offline
Old 02-06-2011, 01:44 PM
ShaneM
ShaneM's Avatar
i put the vmp 500 kit on my car not long ago, it put 420whp down and 408tq on a tune that was really rich in some places. All i can say is once you get the tune and pulley on, go to a dyno before you get on it to be sure all is well. my first vmp tune was very lean, i had to add 4% fuel to get the AFR where it needed to be. That tool VMP sells is worth the money for press onpullies. As for your car, isn;t that a bolt on? I didn't think you needed the pulley remover with the bolt on cars. i think they went press on in 09 IIRC.
ShaneM is offline
Old 02-06-2011, 03:56 PM
fredlo69
fredlo69's Avatar
My Roush is a 06 but the M90 has the press on pulley. I purchased a vmp 500 kit and I will be installing it as soon it gets in, I was told by another Roush owner I can use the 3 jaw pulley puller which I already have. He also suggested to us a power steering pump pulley installation / removal tool for the install of new smaller pulley. This tool is rented for free actualy at any autozone or autobarn after leaving a deposit. I will dyno after install to keep engine safe. Thanks for input.
fredlo69 is offline
Old 12-18-2011, 07:45 AM
wcgman
wcgman's Avatar
Did you end up using a power steering pump pulley remover installer you rented? Im thinking about the upgrade but the VMP tool is a little pricey.
wcgman is offline
Old 12-18-2011, 08:10 AM
ShaneM
ShaneM's Avatar
that vmp pulley remover is pricy, but it will get that pulley on and off in a minute with no damage at all.
ShaneM is offline
spdeplayer2
10-24-2015 09:45 AM
Gene K
10-21-2015 11:37 PM
firecoyote
09-27-2015 02:37 PM
09-03-2015 07:14 PM
Quick Reply: M90 roush supercharger pulley removal
