Innovate Motorsports MTX-L Wideband A/F
So I am thinking about getting an A/F gauge, and considering the Innovate Motorsports MTX-L. I'm considering this one because it's all-digital, and can take the place of one of my stock O2 sensors (read, no need for a new bung). They also advertise it as having the quickest reaction time. It also has a serial in/out, so I could theoretically use it to help with a dyno tune.
My questions are:
1. Has anyone used this particular gauge?
2. Is this a reputable gauge?
3. Would I run into any issues with only running the one gauge?
Thanks guys
My questions are:
Thanks guys
From this page: "It is possible to install the wide-band sensor in place of the OEM oxygen sensor. In this case the meter's analog output signal will replace the OEM oxygen sensor's signal to the fuel injection computer. EFI equipped cars typically incorporate a narrow band oxygen sensor. These sensors are typically 1, 2, 3 or 4 wire sensors. "
Note: I read this same thing in the MTX-L manual (I love manufacturers that have downloadable PDF manuals!)
from your post, it uses a WB sensor in the OEM sensor location, so it is still a WB.
just no need to have a separate bung welded.
i would suggest you do a WB and not narrow band bc it is more accurate for FI purposes.
the hardest part about the install is routing the wires.
heres a nice write up about gauge installs.
https://mustangforums.com/forum/2005...installed.html
I'm still wondering if it would ever be a problem to be only monitoring one side of the engine though.
09-16-2015 07:53 PM
