Sponsored by:
Sponsored by:
2011 gt supercharger + meth results
Old 07-29-2011, 10:07 PM
  #41
Element155
Element155's Avatar
Originally Posted by siggyfreud
Any concerns about the meth going through the supercharger itself? Doesn't it hurt the cooling benefits a bit to have the meth compressed? I suppose more gained than lost though?
its all positive, cools the rotors and air, reduces detonation, probably helps to keep the rotors and intercooler cleaner (its alcohol). meth is awesome and cheap, call alky control and don't look back. water/meth kits are not as good as strait meth kits cause you cant burn water.
Element155 is offline
Old 07-29-2011, 10:53 PM
  #42
JIM5.0
JIM5.0's Avatar
Just a thought about water for anti detonation: the reason why it is used is to simply draw heat out of the hot combustion chamber. You are right; it does not aid in combustion concerning it being burnt along with the fuel. But it's advantage is that it has a higher specific heat meaning it can suck more heat out of the cylinder than alchohols can. Also, depending on how much water is shot in, the water vaporizing into steam can also add to pushing the piston down. There are some hypothetical engines called six stroke engines that uses the forces of steam as one of the power strokes.
JIM5.0 is offline
Old 08-13-2011, 09:01 AM
  #43
Element155
Element155's Avatar
I'd love to try h20/meth combo to see what it produces in comparison but my pump is only engineered for strait meth, very interesting, i would also like to see what would happen if I ran the meth and my gas though a chiller to see if that might help with a more efficient release of energy. Thanks for the info. I'm currently paying for the trans to be upgraded and engine is coming this winter but the big thing i'm considering as further chemical enhancement for next level cooling upgrade is Cry02 setup with fuel blocks and heat exchanger sprayer.
jwog666
12-27-2021 08:09 PM
TCStangerv6
10-11-2015 05:57 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: 2011 gt supercharger + meth results
