Sponsored by:
Sponsored by:
18/19'' wheels
Old 08-15-2011, 10:37 PM
Warpig12354
Warpig12354's Avatar
Default 18/19'' wheels
How will this affect my speedometer? If anything.
Warpig12354 is offline
Old 08-15-2011, 11:09 PM
HenryinFlorida
HenryinFlorida's Avatar
If you use tires with the same diameter there won't be any change at all. For example, on your 18 in wheel you can run 255/45-18 tires and keep the same 27 inch diameter as stock. I wouldn't go beyond the 18 wheels. The tires get very thin and feels like your on solid rubber tires IMO. I went with some 2010GT500 convertible wheels that were 18X9 1/2, used the 255/45-17 Hankook v12 tires and am very happy with them.
HenryinFlorida is offline
Old 08-16-2011, 12:26 AM
Warpig12354
I was looking into getting these.
Old 08-16-2011, 06:05 AM
HenryinFlorida
Those look great also. I got these wheels:
http://www.buyfordracing.com/product...-SET-OF-4.html
and these tires:
http://www.tirerack.com/tires/tires....omCompare1=yes
Old 08-16-2011, 08:23 PM
Warpig12354
Did you get a TPMS sensor put in them? If so, how much was it?
Old 08-16-2011, 08:54 PM
HenryinFlorida
I bought the TPMS kit from American Muscle for $149. It included everything needed including the reset tool. I installed them on my rims before I took them to have the tires mounted and balanced. I also needed the steering limiters made by roush. Got them from AM for $10. They were so easy to install and did the trick with these wider tires and rims.
Old 08-16-2011, 09:03 PM
Warpig12354
Cool, thanks.
Old 08-17-2011, 09:00 AM
Chromeshadow
Chromeshadow's Avatar
I have those rims, with the 555 Nittos, great combo!! I got the TPMS sensors with them, AM installed the sensors and mounted the tires...All I had to do was mount the tires on the car and reset the sensors. AM has a tool that does that for you, along with instructions. It really changed the look of the car and really helped the handling.
Chromeshadow is offline
jwog666
12-27-2021 08:09 PM
UrS4
10-03-2015 06:23 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: 18/19'' wheels
