No, no harness. It was only the two headlamps. I believe the ones from ford comes with everything you need, but then you'll have to pay like 2 grand for them. I will post pictures as soon as I get home.
? thread started as "ordered the oem hid's", yet you didn't?
sure i would not want to spend 2 grand on that gizmo, so the question is which/where did you order the hid's? price? instructions? apparently no harness!? how are they meant to be installed/connected?
If all you ordered was the housings, then you are going to have to either get the stock wiring harness/ballasts or some aftermarket wiring/bulbs/ballasts and so with what you have, you won't be able to install even after you get the right side housing. might should have gotten the whole kit like what Steeda sells.
