Sponsored by:
Sponsored by:
JBA Header question..
Old 05-05-2012, 03:52 PM
slickman
slickman's Avatar
Default JBA Header question..
Has anyone installed these and can you tell me if you ran into any problems?
http://www.americanmuscle.com/jba-sh...rs-0509gt.html
slickman is offline
Old 05-05-2012, 10:57 PM
stealth_GT
stealth_GT's Avatar
I did on my 08 but with the motor out of the car.. no problems but it might be a tight squeeze with the motor in the car still.. I think I used the stock gasket and a gasket maker at the time. I don't remember, long term memory shot.. short term as well lol
I recommend the high heat ceramic titanium coated type. Supercharged, 10 psi, mods, drag racing etc. stayed cool to the touch..
stealth_GT is offline
Old 05-05-2012, 11:12 PM
3vStang
3vStang's Avatar
A friend of mine said they were a really tight fit on his, but you never know. I had no fitment issues when I installed my kooks, that is if your looking at other brands.
3vStang is offline
Old 05-06-2012, 03:49 AM
stealth_GT
stealth_GT's Avatar
Ditto.. why shorties?
trying to stay emissions friendly eh?
LT's flow so well, it might make more power than you're wanting to make especially with that 11 psi..
Old 05-06-2012, 03:50 AM
SON OF 68
SON OF 68's Avatar
Do-able, but not easy! If you have means of a lift I'd strongly suggest it. I used bolts on some and studs on others. Stayed with stock gaskets too.
SON OF 68 is offline
Old 05-06-2012, 04:49 AM
MadMike1337
MadMike1337's Avatar
Only issue i had was the header hitting the steering shaft on the driver side. I fixed it by putting prothane MM in.
MadMike1337 is offline
Old 05-06-2012, 10:32 AM
slickman
slickman's Avatar
I already installed prothane motor mounts. The reason I was thinking about shorty's, I don't feel like messing around or the expense of replacing the cats. I just wanted to increase the flow over the stock exhaust manifolds.
slickman is offline
Old 05-06-2012, 11:48 AM
SON OF 68
SON OF 68's Avatar
I like the JBA's myself. I did them and the cams at the same time. Some say you lose some bottom end with cams. If that's the case, then I picked it back up with the headers. I also did the shorties for the same reason pretty much.
1.) I didn't want to mess with the cats as I have to pass emissions here.
2.) I couldn't justify another $1000-$1200 over the cost of the shorties for what you might gain.
I know LT's are better flow wise and performance, but couldn't spend that much more. Not for what I use the car for. If I were going to the track a lot, yes! But it's just for nice day, and weekend fun.
Old 05-06-2012, 12:24 PM
slickman
slickman's Avatar
Yup, my reason exactly, emissions. I had Hooker long tubes (super comps) on my 72 Nova but, that's in a class with less emission restrictions. So, I know LT would be the performance way to go but, I need to keep the cats. I don't want to get an entire new custom exhaust (with new cats) just to have LT. So, I have my eye these shorties; http://www.ebay.com/itm/270926067256...84.m1436.l2649
Cheep copies of the JBA's..
slickman is offline
Old 05-06-2012, 02:28 PM
stealth_GT
stealth_GT's Avatar
I don't blame you. the stock log style manifolds suck
Quick Reply: JBA Header question..
