Sponsored by:
Sponsored by:
Rough shifting in cooler weather
Old 10-12-2012, 10:35 PM
  #21
JThor
JThor's Avatar
Originally Posted by kevinmalec
Mechanic test drove the car and said that it felt difficult to shift from 1st to 2nd, when hitting the throttle hard. He said it felt normal during regular driving. I went ahead and had the tranny fluid replaced out yesterday. The shifter seems a little better, but still feels a bit clunky. My commute is only 3.7 miles to work and back, so I am not sure if the short drive allows the car to warm up enough to tell. LOL
I am thinking maybe this is how the new clutch and shifter is suppose to feel?
If it started right after you replaced the clutch, then it is probably a clutch issue. It is possible that the mechanic didn't fully bleed the slave cylinder. So, the clutch is not fully disengaging. It's more noticeable on a 1st to 2nd shift.
Also, since you had a slave cylinder T/O bearing issue before, it's possible that there is something still wrong there. You might want to take the car to another mechanic to get a second opinion and check the first mechanic's work.
JThor is offline
Old 10-15-2012, 01:33 PM
  #22
kevinmalec
kevinmalec's Avatar
The whole clutch was replaced out at 65,XXX and the car just turned 68K . With that said, I drove the car over 2,000 miles and didn't really experience any issues until the weather started to cool down significantly in the mornings. If there are issues with bleeding the slave cylinder, would I have experienced as soon as I received the car back from the shop?
kevinmalec is offline
Old 10-15-2012, 02:56 PM
  #23
Derf00
Gentleman's Relish
Derf00's Avatar
The only other thing I can think of is the shifter arm has a bushing (rubber) that connects from the shifter arm onto the shifter plate at the top of the tranny. If that is worn, and since the tranny was recently removed, that bushing could be shot and causing a misalignment. fordparts didn't list that bushing separately but I'm sure it's available aftermarket (the entire arm is like $320)
Derf00 is offline
Old 10-16-2012, 10:03 AM
  #24
kevinmalec
kevinmalec's Avatar
Derf00 ^^Appreciate you chiming in^^
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
Thunderball
15
11-22-2015 11:49 PM
Explosive
10-02-2015 07:45 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Rough shifting in cooler weather
