Sponsored by:
Sponsored by:
Anyone running 275 on 9" wheel
Old 05-23-2013, 04:38 PM
obxdude018
obxdude018's Avatar
Default Anyone running 275 on 9" wheel
Not really tech based, purchased a complete set of 275/40/18 from AM, went to the shop to have them installed and guess what I was turned down because the tires won't fit on. Called AM, and like usual best service out there verified that they should fit and that it was the shop who was probably scared to mount the tires.
obxdude018 is offline
Old 05-23-2013, 04:50 PM
moosestang
moosestang's Avatar
I have 275/50/17's on 17x9's. Next i'm putting 295/45/17's on the same rims. These are drag radials of course, not street tires.
moosestang is offline
Old 05-23-2013, 05:50 PM
NC97Cobra
NC97Cobra's Avatar
Im running 275/40-17 on my Cobra. Nitto 555s of course. They fit great and look wide as hell.
NC97Cobra is offline
Old 05-23-2013, 05:53 PM
NC97Cobra
NC97Cobra's Avatar
****However....... I would not suggest bigger than 255 on a 9 inch wheel for the front unless you are running a 1/4 inch spacer. Im cutting it tight on my 97 Cobra with a 245 and no spacer. I rub my inner fender and have about a 1/4 inch clearance to my A-arms/shock tower/suspension stuff.
Old 05-23-2013, 06:06 PM
95Bluestallion
95Bluestallion's Avatar
I had 275 on my stock 17" tribars that are only 8 inches wide. The drag radials went on easy, the shop struggled mounting regular hard sidewall street tires, but got it done. Try another shop, it can easily be done, and I plan on doing it on the front of my S197 very soon.
95Bluestallion is offline
Old 05-23-2013, 06:28 PM
2005Redfire6
2005Redfire6's Avatar
My brother has 275's on 9" AMR wheels and he actually got them from AM mounted on there already....
2005Redfire6 is offline
Old 05-24-2013, 07:02 AM
Nuke
Nuke's Avatar
What do the specs say for that tire? My 9.5" wide 18" GT500 wheels typically max out at 285 for about 99% of the tire specs that I reviewed. I'm running 275's all around on that wheel.
Nuke is offline
Old 05-24-2013, 03:55 PM
americaniron
americaniron's Avatar
My front rims are 18x9s, and I have 275/35 Nitto NT05s mounted on them. I haven't had any problems with them at all. They are however the max size that Nitto recommended for it.
americaniron is offline
Old 05-24-2013, 05:36 PM
Norm Peterson
Norm Peterson's Avatar
The shop is wrong.
9" is indeed wide enough to properly fit a 275/40 tire - even though it's the narrowest recommended width wheel for that size tire, that still means that it is acceptable.
Norm
Norm Peterson is offline
Tivo304
08-28-2023 12:19 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Anyone running 275 on 9" wheel
