Sponsored by:
Sponsored by:
Cam install need help!!
Old 12-24-2013, 12:56 PM
clix813
clix813's Avatar
Exclamation Cam install need help!!
So im half way threw the install first side driver side took alot of effort to get the cam in. I think it wasnt at top dead center. I have udp so its hard to tell. The left side was very easy. If it was not at top dead center what do I do did I mess up. I thought that since nothing has slipped off for timing I should be fine.... At least I hope so.
Thanks,
Matt
clix813 is offline
Old 12-25-2013, 08:28 AM
clix813
clix813's Avatar
Ok so after doing everything the car ran great. For a while. Idled great ran great pulled good. I thought I was in the clear. Then I started it a while later took it for a drive. Then it started to have a miss. I am getting p0345, p0349, and p0021. I am thinking it slipped a tooth I just don't know how cause the lines on the gear lined up. I am now just confused as of what to do. Any input would be great. O and merry Christmas every one.
clix813 is offline
Old 12-25-2013, 08:47 PM
Greed1
Greed1's Avatar
Cam sensor codes? Check cam sensor plugs.
Greed1 is offline
Old 12-26-2013, 12:04 PM
clix813
clix813's Avatar
Sensors are fine I am starting to pull things now. I will go back over my work for like the 6th time. I am going to pull them then re install them and see if I get any changes.
clix813 is offline
Old 12-26-2013, 04:02 PM
Greed1
Greed1's Avatar
Did you use a wedge or other method to isolate the timing chain? Crank at TDC doesn't really matter. Just makes the cams easier to install due to less followers with pressure on them. If you wedged the chain and your marks lined up between the phaser and chain, I don't see how it could have jumped timing. Assuming tou did not use a spring compressor.
Greed1 is offline
Old 12-30-2013, 10:18 AM
clix813
clix813's Avatar
So I must have had it slightly off centered cause worst thing happened. The thrust bearing cap cracked. The cam moved slightly forward and the phaser was contacting the cam position sensor. So I guess I am in the market for a used head now since those parts are mated to each head.
clix813 is offline
mtgldr
02-03-2024 09:00 PM
Luke9222
10-22-2015 11:55 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Cam install need help!!
