Sponsored by:
Sponsored by:
Gauge Cluster Problem.
Old 10-27-2014, 06:51 PM
lynly4.6
lynly4.6's Avatar
Default Gauge Cluster Problem.
Okay, so this is my 7th mustang but my first of this body style, I just bought a 2005 Mustang GT Manual its got a Power Akoustic radio in it (the previous owner put it) but as soon as i drove off the lot my gauges started messing up, like my RPMs werent reading at all, speedometer wasnt working, and neither was my coolant temp gauge... so i take it back to the dealer and ask them to run a diagnostic test on it, they said it could be the after market radio.. could that be true? ive never heard of that nor does it make any sense. Thanks!!
lynly4.6 is offline
Old 10-27-2014, 07:02 PM
bl817
bl817's Avatar
not related to the radio at all. sounds like it had issues prior and your now having to deal with said problems. sounds like the stepper motors in the cluster are bad and need replaced, its not a huge problem if your good with soldering and small electronics. there are places you can find that do this repair fairly cheaply though.
bl817 is offline
Old 10-28-2014, 12:50 PM
Nuke
Nuke's Avatar
2005's thru mid 2006's have chronic gauge issues. The problem is with the stepper motors. Do a search in the forum and you'll get an avalanche of info.
Nuke is offline
Old 10-28-2014, 05:30 PM
2005Redfire6
2005Redfire6's Avatar
+1, I had to replace my cluster after a failed stepper motor change. However if you are patient and have a steady hand with a solder gun it is easy to do.
2005Redfire6 is offline
Old 10-31-2014, 09:10 AM
SteveDwsn
SteveDwsn's Avatar
If they didn't have the radio to blame, it would have been the way you pulled off the lot.
SteveDwsn is offline
jwog666
12-27-2021 08:09 PM
5.0muscle
01-11-2016 01:17 PM
andrew1969
16
01-08-2016 02:48 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Gauge Cluster Problem.
