Sponsored by:
Sponsored by:
06 Antenna Base mounting, what am I missing?
Old 07-14-2015, 04:38 PM
MustangFalcon
MustangFalcon's Avatar
Default 06 Antenna Base mounting, what am I missing?
Hi, I recently bought an 06 mustang convertible with a rebuilt front end, one thing that was never completed was the antenna install. It is not secured to the car and I do not want to install the mast without it secured to avoid chewing up my fender. It comes right out and I can tell bolting it in won't do much, what am I missing? Any help would be appreciated Thanks
MustangFalcon is offline
Old 07-14-2015, 06:55 PM
DRAGUL
DRAGUL's Avatar
I am taking a guess that the part your screws are screwed into at the bottom of the antenna base are rivnuts and should be attached to the fender.
DRAGUL is offline
Old 07-14-2015, 07:01 PM
MustangFalcon
Thanks any idea how I go about securing them to the fender?
Old 07-16-2015, 09:13 PM
jz
jz's Avatar
When I took my antennae off a few years back, the nuts were attached to the fender. I'm not sure how, because I had no reason to look. But it appears to me that you only have through holes in your fender. Looks like the nuts are missing.
jz is offline
Old 07-16-2015, 09:34 PM
MustangFalcon
Thanks, they were rivnuts which use a special gun, I couldn't find anyone that had one so I ended up using drywall anchors and larger bolts which so far is working out well.
DRAGUL
DRAGUL's Avatar
I would go to a auto body shop and see if they can secure it for you.
DRAGUL is offline
jwog666
12-27-2021 08:09 PM
kevsgt
10-09-2015 10:12 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: 06 Antenna Base mounting, what am I missing?
