Sponsored by:
Sponsored by:
Horrible noise and the search for an actuator/condenser.
Old 08-30-2015, 12:45 PM
Kenta08
Kenta08's Avatar
Default Horrible noise and the search for an actuator/condenser.
Heya.
My 2008 V6 Mustang has been running fine for years, but unfortunately in March something went goofy and my dash has been emitting this AWFUL clicking sound every time I turn on the A/C.
So I did some searching and I found out "oh, this is my actuator." I get online, order up the part I need, and then when I finally uninstall the other one and try to slide the new bad boy in... well... it doesn't fit.
(Before I get too deep I'd like to note that it makes this sound both with and without the actuator installed / attached. I've heard similar noises on YouTube videos. Feel free to stop me here if I'm off or looking at the wrong part)
When I search online for other parts I get told "this is not the part that fits your car," but then it recommends me similar ones that are identical to the one I bought. The easiest way to tell them apart is the crank-shaft arm; the Dorman 604-232 has one, but it's not fitting.
Update: When I search for something akin to the part number I see etched on it I get this result, but I'm also told it doesn't fit: http://www.amazon.com/Genuine-Ford-A.../dp/B00GJJ088U
I threw some pics up online too...
New part: http://imgur.com/DodhiAK
Old part: https://i.imgur.com/BgVYjII.jpg
I'd really appreciate any help or suggestions. I'm pretty confused by this, and I feel like I'm missing something basic.
Thanks!
Kenta08 is offline
Old 08-31-2015, 06:35 PM
SpartaPerformance
SpartaPerformance's Avatar
If you're going aftermarket aka "Dorman" thats your problem get a Motorcraft and be done with it. Also make sure you're getting the right actuator, blend door or temperature
SpartaPerformance is offline
Old 09-02-2015, 10:33 AM
2007CalSpec
2007CalSpec's Avatar
Originally Posted by Kenta08
Heya.
Thanks!
You said it still makes the noise with or without the actuator installed? Sounds like you removed the wrong actuator. There's 3 actuators (Air Inlet, Defrost and Panel/Floor). I don't trust Amazon for recommending parts that fit. They've been wrong before in my experience. I buy most of my replacement parts at Rockauto.com. I had to replace the one under the passenger side dashboard. I felt around underneath while turning the climate controls on and off until I felt where the clicking was strongest. I heard the one on the driver's side (Panel/Floor) is the hardest one to reach but it's doable.
http://iihs.net/fsm/?dir=336&viewfil...let%20Door.pdf
Attached Thumbnails Horrible noise and the search for an actuator/condenser.-screenshot-1-.png
2007CalSpec is offline
jerrytubes
10-23-2015 12:11 PM
Dokilar
15
10-16-2015 08:13 PM
kevsgt
10-09-2015 10:12 PM
KingRando
10-02-2015 08:06 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Horrible noise and the search for an actuator/condenser.
