3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
What is the difference between ?
Old 05-03-2012, 06:34 AM
Double Tap
Double Tap's Avatar
Default What is the difference between ?
What us the difference between the Auto Trans in the V6 vs the V8. I am thinking of doing a Procharger and I am wondering if the Trans in my V6 can handle the extra power.
Double Tap is offline
Old 05-03-2012, 07:34 AM
2k232
2k232's Avatar
Think its all the same trans back compared to a gt I may be mistaken tho.
2k232 is offline
Old 05-03-2012, 12:15 PM
Moderator
JimC's Avatar
If it is like the 2005-10 the transmission then was the same (5r55s) but the input shafts were different so they weren't iinterchangeable. But other than that they were the same. I haven't seen the comparison for the 2011+ though. They do take the same filter according to rockauto.com but it doesn't say what the actual transmission is.
JimC is offline
Old 05-03-2012, 12:30 PM
JayyVee
JayyVee's Avatar
AM's '11 v6 project car is an auto, with procharger on it. Believe they are putting 470ish down at the crank w/ procharger and other mods safely, and being run at the dragstrip?
http://www.americanmuscle.com/2011-v6-project-car.html
JayyVee is offline
Old 05-03-2012, 05:40 PM
I_Call_D.I.B.s
I_Call_D.I.B.s's Avatar
Both the V-6 and the V-8 use the 6R80 automatic transmission, but have different gearing.
2012 GT gear ratios:
1st 4.17
2nd 2.34
3rd 1.52
4th 1.14
5th 0.87
6th 0.69
2012 V-6 gear ratios:
1st 4.171
2nd 2.34
3rd 1.52
4th 1.43
5th 0.86
6th 0.69
I_Call_D.I.B.s is offline
Old 05-03-2012, 05:44 PM
03gt04mach1
03gt04mach1's Avatar
Also V8 Trannys have more Clutch Frictions and Plates in the Drums, and I think FIRMMER Shift Pressures. A little more heavier duty than a V6 Tranny.
03gt04mach1 is offline
Old 05-03-2012, 06:48 PM
Double Tap
Double Tap's Avatar
After looking at the AM video of the V6 project car I think the Transmission can handle the Procharger. Now all I have to do is convince my wife that it will be $$$ well spent O:-)
Old 05-03-2012, 06:53 PM
03gt04mach1
HEY! Tell her you're going to get great gas mileage now. Just don't tell her that's just while it's sitting in the driveway though.
Dokilar
15
10-16-2015 08:13 PM
breaking
10-02-2015 01:27 PM
UrS4
09-30-2015 10:13 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: What is the difference between ?
