3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Replacing rear shocks
Old 09-18-2014, 09:17 AM
dude90002
dude90002's Avatar
Default Replacing rear shocks
So the other day I was underneath the car tightening my exhaust pipes when I noticed my passenger rear shock had been leaking fluid. The car has over 60,000 miles on it so I guess it's time to replace the rears. I'm thinking of getting the KONI STR.T Rear shocks to replace them with. Does anyone have these on their ride and if so, how do they handle and what kind of tools do I need in order to successfully replace them myself (besides the jack and jack stands).
Also, does anyone with a 2010+ model know what causes the rear to make noise when traveling at 70mph+? It's beginning to worry me.
dude90002 is offline
Old 09-19-2014, 02:42 PM
2011V6Nicole
2011V6Nicole's Avatar
The koni's are nice they are a little stiffer than stock....as for tools I used an impact driver to get the bots off (there's only 2) but thats just because I have one...you could probably get it with sockets/wrenches.
2011V6Nicole is offline
Old 10-27-2014, 08:47 AM
Jande063
Jande063's Avatar
I personally would not use the impact wrench on the nut that is in the trunk, as tightening that nut too far can damage the internals of the shocks (a friend is an engineer with Koni, his words, not mine). Just use a pair of combination wrenches (9mm and 15mm I think, it has been about a year), and it can help to put the back seats down, then just lay in the trunk, or the angle will get old quickly.
Jande063 is offline
Old 10-27-2014, 10:38 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
I'd also consider the Strange 10-way adjustable shocks. They're a great value at 89/ea.
http://www.uprproducts.com/strange-m...-shock-05.html
What's the rear end noise you have? Gear noise?
UPRSharad is offline
Old 10-29-2014, 08:57 AM
dude90002
dude90002's Avatar
I had issues getting the bolts off the top so I wound up using an impact wrench while my uncle held the shaft from the wheel well. I don't think they're tight enough now though because it sounds like there's a squeaking coming from back there..... I tried tightening them some more but I can't seem to get the shaft to stay still while I tighten the bolt. Oh well.
As for the metal sound, I finally figure it out. There's some metal plates under the carpet where the backseats are anchored in up top. They apparently vibrate when driving down the road.
Old 11-04-2014, 11:40 PM
yourmom6990
yourmom6990's Avatar
I installed a rear strut brace and had to remove these nuts also. What worked for me was a pair of locking pliers at the very top of the stud and then used an adjustable wrench to tighten the nut while holding the pliers firmly.
yourmom6990 is offline
drfister
05-03-2018 10:38 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Tyoung68
08-25-2015 04:31 AM
dangthatsfast
08-06-2015 09:46 PM
Quick Reply: Replacing rear shocks
