351 Mustang
cam shaft problems
Old 03-07-2006, 11:01 PM
mark54
mark54's Avatar
Default cam shaft problems
[:@]i was wondering if any body out there can help me with this problem. I have started to build my motor and will hopefully be dropping it this weekend but for some reason i can't get the camshaft to set in the bearings. this is the first motor i have put together so i'm pretty sure it is something i am doing wrong. when i slide the cam in through the front the distributor gear gets caught on the front bearing and will not go all the way in. theres the problem here my question the freeze plug on the back of the block was left off and came in a bag with my motor. Is this because i need to put the cam in from the back??? Like i said Im sure this is a problem caused by inexcperience. Can any body help?[:
mark54 is offline
Old 03-08-2006, 12:45 AM
mkspeed26
mkspeed26's Avatar
Default RE: cam shaft problems
no, the cam does go in the front. that is just a plug for the back. what about the cam bearings? are they new installed or not changed?
mkspeed26 is offline
Old 03-08-2006, 10:35 AM
mark54
mark54's Avatar
they're new bearings. it slides in real nice up until the distributor gear
mark54 is offline
Old 03-08-2006, 11:07 AM
S351R13
S351R13's Avatar
Check to see if the bearing is installed wrong or is the wrong bearing. Are you using the correct tool to install the camshaft?
S351R13 is offline
Old 03-08-2006, 11:21 AM
mark54
mark54's Avatar
shouldn't all the bearings be the same . i have an exxtra set of bearings and none of them will fit over that part of the cam. Did they give me the wrong cam?
mark54 is offline
Old 03-08-2006, 03:46 PM
88BlueGT
88BlueGT's Avatar
Where did you get the cam from?
88BlueGT is offline
Old 03-08-2006, 05:34 PM
mark54
mark54's Avatar
never mind its in
mark54 is offline
Luke9222
10-22-2015 11:55 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
vintageaion
09-08-2015 10:45 AM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: cam shaft problems
