351 Mustang
Stock EFI swap to Projection II EFI on my 5.8 in my 95
Old 07-30-2012, 07:34 PM
Kozz167
Kozz167's Avatar
Default Stock EFI swap to Projection II EFI on my 5.8 in my 95
http://sn95forums.com/showthread.php...-Sticky-please
The post above is the only one that I have been able to find, and it is a EFI to Carb swap.
I want to put the projection EFI from Professional Products on my 351 that I is in my 95, and I do plan on boosting it latter on. But I relay would like to know is this a good Idea and how much torque I will loose with this set up and if it is worth it. I also have 393 kit for latter to add with the boost. But for know will swapping out this EFI Projection kit give me my bang for the buck with a basic stock 351 with an E303 cam and GT40 heads?
It might be two years till I get the 393 ready and boost.
She is just my toy and not a Daily drive, and I don't have inspections.
Kozz167 is offline
Old 08-02-2012, 12:08 PM
Kozz167
Kozz167's Avatar
Still would like to get any opinions on this, and or help please.
Kozz167 is offline
Old 08-18-2012, 07:11 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
why not just keep what you got a run a tweecer and get a tune?
rmodel65 is offline
Old 08-19-2012, 12:52 PM
Kozz167
Kozz167's Avatar
rmodel65 thank you.
I have only heard of the tweecer on here and I have not found it yet to look in to. I'm also not in a location were I can just go and get a tune on a dyno even though I would like to, and a mail order tune just does not sound right(old school seat of paints road tune). I was also looking at an Anderson PMS. I did deiced to just do the 393 build know rather than later. I am leaning heavy towards turbo's also.
Kozz167 is offline
Old 09-05-2012, 11:04 PM
Venomantidote95
Venomantidote95's Avatar
HLY-550-401 This would be more suitable for that cuin and boost! they offer upgrades when needed also!
Dont skimp on aftermarket efi systems you can get into a real headache doing so! A FAST setup will work well also but once you reach a certain power level you will have to get there upgrade also!
If you have a factory efi setup keep it and go from there, you can use a moates quarter horse system and never upgrade just tune.
A wideband and the qtr horse will get you to any level you want to reach, you will have way less invested in this than most other tuning setups!
Venomantidote95 is offline
Old 09-09-2012, 07:11 PM
82 351 roller
82 351 roller's Avatar
I saw a nice set up on a car stock lower sheet metal upper so it could fit under stock hood stock wiring harness and the guy is in same boat as you for tune he sent specs to guys in detroit goes like a raped snake still cost him around $2000 for whole set-up.SO pretty much like Venomantidote95
82 351 roller is offline
97SN95GT
09-13-2015 09:45 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
M3hunter
09-05-2015 03:42 PM
Quick Reply: Stock EFI swap to Projection II EFI on my 5.8 in my 95
