351 Mustang
F4TE 351W
Old 12-23-2014, 12:13 PM
im_stuck_in_iraq
im_stuck_in_iraq's Avatar
Talking F4TE 351W
I recently purchased a 351W from a guy off the Internets. Stamped with F4TE. I believe that means its a roller motor. Not quite sure what that means I believe it has roller cam and rockers? I would eventually some day like to do a 408 stroker. For now I dont think i can swing that.
I did read some of the stickys and things that I can use from my current 94 gt efi. I will prob not use a whole lot from the 302. I think I want to go carburated and swap out to a t5. A buddie of mine suggested AFR 205 heads but beyond that I have no idea what I need. (intake, carb, RR, cam, extreem noob when it comes to motor stuff. I work in IT) It will be a street car and only driven on the weekends and nice days. The occasional track day. I will def spray nitrous. Beyond that I am open to suggestions. It's like I want somebody to help me pick out the correct parts so I dont get fd or buy parts that dont work etc.
The motor does spin freely so i dont think I will need to replace internals for now. Do I need to change cam? Rockers? lifters?
im_stuck_in_iraq is offline
Old 01-01-2015, 09:45 PM
barnett468
barnett468's Avatar
hello;
how much power do you want?
do you want a mild, moderate or rough idle?
i would run at least a scat cast iron crank if you plan on much hp.
if you buy a crank you might as well stroke it
barnett468 is offline
Old 01-02-2015, 06:05 PM
64bit
64bit's Avatar
the 351w has cast pistons... I highly suggest you do not spray it unless you rebuild it with forged slugs.
FWIW, I'm running a 1996 F4TE shortblock (cast pistons and all) in my Cobra. It's currently putting down 565rwhp.
64bit is offline
Old 02-24-2015, 12:21 PM
im_stuck_in_iraq
I want a rough mean sounding idle. Prob would realistically be able to afford a H/C/I upgrade. I would like to take a look at the motor make sure everything is good. Leave it stock if possible then do H/c/I swap and spray a little. Eventually I would like to turbo/stroke it. Going to put a c4 on it. Looking for suggestions on shifters as well.
guitarman376
09-30-2015 05:54 PM
LiquidDrink
09-29-2015 10:06 AM
FoxGT
07-11-2004 11:49 PM
Mustang88LXKid
02-29-2004 08:01 PM
WNDSOR
01-30-2004 09:47 AM
Quick Reply: F4TE 351W
