Gt exhaust fit V6??
Old 09-22-2006, 03:15 AM
Jerseyfury2
Jerseyfury2's Avatar
Default Gt exhaust fit V6??
Hey all...if I have the GT rear fascia and there's an axle back exhaust kit for a Gt....will it fit? And if so, will it fit if i put new headers on?
Thanks for your time,
Mike
Jerseyfury2 is offline
Old 09-22-2006, 03:17 AM
petepete
petepete's Avatar
Default RE: Gt exhaust fit V6??
it will fit but you will need a driver side pipe to put on the 2nd muffler or you can just use one
petepete is offline
Old 09-22-2006, 09:20 AM
HurricaneStang
HurricaneStang's Avatar
Ya everything should fit, just have to get the left side exhaust pipe fabbed which is usually around $150 depending on where u take it.
HurricaneStang is offline
Old 09-22-2006, 12:07 PM
GOTTA06!
GOTTA06!'s Avatar
I did it the cheap way
bought a pair of GT take-offs on e-bay ($70 w/shipping) and had the Y cut out and a driver's side pipe fab'd, $120 and mounted. Then an H-Pipe $35. The mufflers are straight bolt-on. Only problem was OE pipe was 2.5" and my fab place could only bend up to 2.25". So the pipes are different sizes, but nothing anyone will ever notice. the sound is better: has a little rumble at idle and louder under load. So I'm pleased, and glad I didn't do the after-market kits for bigger $
GOTTA06! is offline
Old 09-22-2006, 12:34 PM
HurricaneStang
Where'd you get it done?
Old 09-22-2006, 12:52 PM
AmericanMade
AmericanMade's Avatar
Everything should fit espacually if you get shory headers. JBA has shorty headers that are direct replacment for the factory manifolds. I have them and they went right on. i also have a true dual but I don't know if the GT exhaust kit will fit the same. Mine was kind of custom w/ H-pipe.
AmericanMade is offline
Old 09-22-2006, 06:10 PM
GOTTA06!
GOTTA06!'s Avatar
Got it done at a local "good-ol-boy" shop. The franchise-type places wanted double.
GOTTA06! is offline
Old 03-24-2024, 12:36 PM
anthony alvarez
anthony alvarez's Avatar
Mike
so i currency installing a stock 95 mustang gt h pipe to my 2003 mustang v6. and i ran into this issue where the flange that connects to the headers is different than the one on my y pipe. ima need to get it refabricated for it fo fit. i’m thinking if just cutting off up to where the 02 sensors are and swapping the ends. this is in the passenger side and driver side.
anthony alvarez is offline
Tivo304
08-28-2023 12:19 PM
firecoyote
09-27-2015 02:37 PM
Oak
09-14-2015 03:08 PM
09-10-2015 08:39 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Gt exhaust fit V6??
