Help!! Grinding Noise on 2005 V6
Old 05-16-2009, 06:32 PM
cherrycandy001
cherrycandy001's Avatar
Default Help!! Grinding Noise on 2005 V6
Hello fellow pony owners,
I have a 2005 Automatic V6 and I'm super worried. I started to notice that its been making a noise when I begin to accelerate to about 35-40 mph. After I'm going 40 I don't hear anything. It sounds like metal on metal grinding. It also sounds like its coming from the bottom front of the car. It doesn't always do this but I'd say it does it about 70% of the time. I took it to the shop and they said they can't hear anything but truth is it sounds awful and I have no idea what it is.
Any ideas?
-Candy
cherrycandy001 is offline
Old 05-16-2009, 11:18 PM
cherrycandy001
Anyone??
Old 05-17-2009, 07:17 PM
my first mustang
my first mustang's Avatar
Water pump going bad? Power steering pump? Alternator going bad? Accessory drive belt needs replacing? Many many more possibilities. Find a better mechanic than the one you went to before. Hopefully its not to bad to fix.
my first mustang is offline
Old 06-11-2009, 03:18 PM
nelly_stang
nelly_stang's Avatar
Candy,
Mine does the same thing. Grinding noise in the 35-40 mph range but goes away once I get up to speed. However, mine sounds like it is right under the gear box or shifter. I assume it is something to do with transmission at that range/gear. My car has 110K miles on it but I have not had it looked at for this noise. Did you ever get your looked at again?
nelly_stang is offline
Old 06-07-2012, 04:14 PM
flyhigh@mach1
flyhigh@mach1's Avatar
Sounds like transmission to me
flyhigh@mach1 is offline
bjdutch2005
03-24-2017 03:38 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
Quick Reply: Help!! Grinding Noise on 2005 V6
