8.8 ford explorer fit 2007 v6?
Old 03-21-2012, 03:57 PM
asl9622
asl9622's Avatar
Default 8.8 ford explorer fit 2007 v6?
Hey guys,
Need quick answer if possible. Will a ford explorer 8.8 fit a 2007 v6 ford mustang? Thanks
asl9622 is offline
Old 03-21-2012, 06:57 PM
jimkaray
jimkaray's Avatar
Even if it turns out to be dimensionally the same I'm pretty sure its safe to assume the Explorer doesn't use the 3 Link suspension set up that the S197's do.
jimkaray is offline
Old 03-21-2012, 08:37 PM
asl9622
asl9622's Avatar
Appreciate the response. It is too bad because this rear end has 3.73 gears with t lok.
asl9622 is offline
Old 03-21-2012, 08:40 PM
asl9622
asl9622's Avatar
Is there any other Ford car that I could pull an 8.8 from for the mustang? I have read about using 2 ford ranger passenger side axles.
asl9622 is offline
Old 03-21-2012, 11:47 PM
Moderator
JimC's Avatar
It isn't the axles that is the issue, they are simply inside the axle tubes and could be any number of different set ups depending upon the differential used (tlok 31 spline, or the torsen 33 spline or there is one that is 35 spline for example). And you couldn't use the axles from the same side of a different vehicle anyway - the axles are different lengths because of the distance from the outside where the wheel is mounted to the differential clip.
The axle assembly uses a three link mount - one upper control arm from the center to the bottom of the car, and two lower control arms from the axle tubes to the bottom chassis mounting point. That's why you can't use a rear end from a different model since they use 4 link systems.
JimC is offline
Old 03-22-2012, 02:31 AM
jimkaray
jimkaray's Avatar
That's for Fox body guys who already have an 8.8 but want to convert to a 5 lug set up from the stock 4 lug axle. The Ranger used an 8.8 with a 5 lug axle but the diff was offset to one side so only the right side is the correct length for the Fox Mustang's equal length axles.
jimkaray is offline
Old 03-22-2012, 09:15 AM
asl9622
asl9622's Avatar
Thanks guys. I will look for ford 8.8 for our year
asl9622 is offline
drfister
05-03-2018 10:38 PM
Urambo Tauro
Oil and Oil Related Topics
12-11-2017 07:16 AM
NorthAmericanTuning
03-18-2016 11:21 AM
waid302
09-14-2015 11:19 AM
DCole24
09-11-2015 10:50 AM
Quick Reply: 8.8 ford explorer fit 2007 v6?
