Running wires
Old 04-29-2013, 08:17 AM
FordFan24
FordFan24's Avatar
Default Running wires
Hi there I need to run one ground from a relay under the hood into the cabin, but I don't want to have to make a hole in the firewall to do it.
So my question is whats the best way to run a wire from a foglight relay into the cabin? I was going to use this method
This guy mentions removing the drivers side fender, but I'm not sure where these screws would be located. Is this a good method to use?
FordFan24 is offline
Old 04-29-2013, 11:12 PM
jimkaray
jimkaray's Avatar
You remove the inner fender liner and the plastic fasteners are pretty obvious so you should not have a problem. Its pretty much the only option if you don't want to drill a new hole in the firewall..
jimkaray is offline
Old 05-04-2013, 01:16 PM
IamNobody
IamNobody's Avatar
You can also find a main wire harness that runs from the engine compartment through the firewall and run your wire through that.
IamNobody is offline
2007StangV6
01-28-2016 06:09 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Doogie65
09-06-2015 02:55 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Running wires
