05 V6 Mustang Engine Blown?
Old 01-04-2014, 09:08 PM
MustangVixenGT
MustangVixenGT's Avatar
Holly smokes! Hope you get it fixed soon.
MustangVixenGT is offline
Old 01-04-2014, 09:34 PM
Moderator
JimC's Avatar
Originally Posted by Nyhm
Throttle body spacer and a flowmaster axleback exhaust. So basically nothing.
Very strange, spacer doesn't do anything so it couldn't contribute to that. Flowmasters could only cause back pressure if they broke internally and blocked the exit. Wonder what caused your crankcase to build that much pressure? It takes a lot to break the valve covers.
JimC is offline
Old 01-05-2014, 06:57 AM
teetertotter
teetertotter's Avatar
Originally Posted by JimC
And teetertotter - the 4.0 does not have a "timing belt". It has timing chains on the front driver side and the back of the passenger side. You have to mean the serpentine belt which is not the same thing, and very easy to replace unlike the timing chains.
Yes, Serpentine is what meant to say. Stand corrected. Thanks!
teetertotter is offline
Old 01-05-2014, 02:57 PM
Nuke
Nuke's Avatar
I've never seen valve covers blown off, period. Nasty!
Please don't transfer that TB spacer to the new engine. TB spacers are a joke and you'll have to turn in your man-card if you do.
Nuke is offline
Old 01-05-2014, 03:18 PM
turbo 2.8
turbo 2.8's Avatar
perhaps a combination of blow by and gunked up pcv valve? just guessing since I've never seen this before.
turbo 2.8 is offline
Old 01-06-2014, 11:32 AM
kevinmalec
kevinmalec's Avatar
Wow, this is the first I've ever heard of this issue.....
Makes me think my slow head gasket leak isn't all that bad.
Good luck with the fix!
kevinmalec is offline
Old 01-06-2014, 11:47 PM
IvanRad
IvanRad's Avatar
doesnt look that bad dude. just ducktape it
jk i really hope you find out why this happened
IvanRad is offline
Old 01-07-2014, 01:24 AM
Rudolph Hucker
Rudolph Hucker's Avatar
crankcase pressure.
possibly a broken piston ring..
Rudolph Hucker is offline
Old 01-11-2014, 01:44 AM
tx_zstang
tx_zstang's Avatar
I find that hard to believe that it was only crankcase pressure. But, as Rudolph mentioned, broken or non-sealing rings would cause an intense pressure spike when the spark ignites a charge, and much of the force bypasses the piston and has to go somewhere; the weak points of containment are the plastic value covers and ventilation hoses.
Is the driver-side value cover hose intact? Even if the pcv valve was clogged and completely closed, mild pressure would feed back through the driver side to the intake tube. Normally, the pcv valve does not close all the way on these cars, in any position (unlike older-school pcvs that would actually seal and close).
What oil was being used, and what condition was it in? How cold did it get, too?
tx_zstang is offline
Old 01-17-2014, 07:15 AM
2005Redfire6
2005Redfire6's Avatar
Holy ****! That is insane, curious to find out what ultimately caused that.
2005Redfire6 is offline
ShaneB26154
35
03-04-2021 04:05 AM
NorthAmericanTuning
03-18-2016 11:21 AM
daytooday
08-16-2015 08:22 AM
05slpGT
08-12-2015 02:32 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 05 V6 Mustang Engine Blown?
