AT harsh reverse
Old 03-12-2014, 09:01 AM
Forza_Roma
Forza_Roma's Avatar
Default AT harsh reverse
Almost every time I put AT to R I notice harsh reverse and sometimes not completely smooth shifting (usually when accelarating under low rpm).
But it is very interseting that after I reset the computer (disconnect the battery for few minutes), AT will shift perfect for around 50 - 100 miles. And after that, it'll again start to make not so smooth shifting and harsh reverse. In this way I guess that AT generally is OK and it would also be strange that worn or low level of ATF is causing the problem.
I've searched the web and it says that in 95% of cases the solenoid body replacement will fix the problem.
Any experience with this?
Forza_Roma is offline
Old 03-14-2014, 12:33 AM
tx_zstang
tx_zstang's Avatar
atf fluid, low and/or needs to be changed.
tx_zstang is offline
Old 03-14-2014, 03:47 PM
Forza_Roma
Forza_Roma's Avatar
I plan to do it before the end of the month... I'll let you know, if it'll help.
Old 04-14-2014, 01:28 AM
Forza_Roma
Forza_Roma's Avatar
I changed the ATF and AT shifts better now (maybe not perfect, but definitively better... or maybe I expect too much from AT ), so I guess that the ATF was worn out and also the ATF level was probably incorrect. I doubt it was ever changed before... I only changed 5 litres from pan and filter at 55.000 miles (don't know if 1st owner changed it) and now - at 93.000 miles I did the complete flush of AT system.
I've also noticed a little bit better gas mileage with last tank, but I guess it should be tested a little bit more to completely confirm this.
Old 04-16-2014, 03:01 AM
tx_zstang
tx_zstang's Avatar
Make sure the connector on the bottom-driver side of the trans is plugged in properly, and the smaller of the 3 front connectors on the pcm is properly seated.
mungodrums
09-28-2015 10:54 PM
foxdude
09-24-2015 08:45 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: AT harsh reverse
