2007 Mustang - Remove Parking Brake Cable Tension Prior to Replacing Rear Calipers?
Old 10-15-2014, 01:19 PM
discgolfdc
discgolfdc's Avatar
Default 2007 Mustang - Remove Parking Brake Cable Tension Prior to Replacing Rear Calipers?
Hello, all.
I have a 2007 Mustang (base model, 4.0L 5 spd) and have to replace the rear calipers. Having looked at a number of sources, I keep reading that the removal (and reinstallation) of the parking brake cable from/to the calipers is a bit of a headache.
My question is this: Is there a reason why those who do this repair don't reduce/remove the tension in the parking brake cable at the lever? Would it not make sense? Are there any arguments for why someone would not want to do this?
All input is welcome. Thanks!
discgolfdc is offline
Old 10-15-2014, 02:22 PM
tradosaurus
tradosaurus's Avatar
When I changed the rear pads on my 2008 V6 Mustang I just made sure the parking brake was not activated and used the special tool to wind the caliper piston back.
Then I bled the entire brake system.
I did not remove the parking brake cable.
tradosaurus is offline
Old 10-15-2014, 02:55 PM
discgolfdc
discgolfdc's Avatar
Default Replacing calipers, not just pads/rotors
Hi.
I do have the appropriate tools to compress/wind the brake piston, but in this case, I am replacing the entire caliper on both sides, not just the pads and rotors.
Thanks!
Old 10-15-2014, 03:38 PM
Derf00
Gentleman's Relish
Derf00's Avatar
On a 05+ its easy...its the 99-04 that sucked.
here's how on the 05+ . The first 3 pics illustrate it perfectly.
http://www.americanmuscle.com/jm-rea...9-install.html
The main thing as Tradosaurus pointed out is to make sure you don't have the hand brake engaged. Chock the front wheels so the car doesn't roll.
Derf00 is offline
Urambo Tauro
12-17-2016 03:30 PM
Urambo Tauro
09-07-2015 12:47 PM
inyadreems
08-21-2015 09:10 AM
daytooday
08-11-2015 09:22 AM
Gregz
08-11-2015 03:42 AM
Quick Reply: 2007 Mustang - Remove Parking Brake Cable Tension Prior to Replacing Rear Calipers?
