Tapping into Reverse wiring
Old 07-17-2015, 06:29 PM
vbrecken
vbrecken's Avatar
Default Tapping into Reverse wiring
Just bought a rear view camera to support my Pioneer head unit. I need to tap into the wire running to the reverse lights. Anyone able to pinpoint specifically which wire I can tap into?
vbrecken is offline
Old 07-18-2015, 07:49 AM
bl817
bl817's Avatar
according to chiltons, left reverse lamp is dark green/orange or white/yellow. right reverse lamp is white/yellow. these wires would be found in the trunk behind the panel in the harness that leads to each tail light. if your unfamiliar with wire color codes, first color is wire case cover and second is stripe color. (DKGR/OR is dark green wire with orange stripe) good luck
bl817 is offline
Old 07-18-2015, 08:41 AM
bl817
bl817's Avatar
bl817 is offline
Old 07-22-2015, 10:29 PM
vbrecken
vbrecken's Avatar
Well I spliced into the White/Yellow wire running down the passenger side (actually two of them and I tried both) but the camera did not come on when I shifted the car into reverse (manual). The instructions for my head unit say the following...
"Of the two lead wires connected to the back lamp, connect the one in which the voltage changes when the gear shift is in the REVERSE (R) position. This connection enables the unit to sense whether the car is moving forwards or backwards"
Am I tapping into the correct wires?
vbrecken is offline
Old 07-23-2015, 09:49 AM
vbrecken
vbrecken's Avatar
Got it! There were two WHT/YLW wires. I was tapped into the wrong one.
vbrecken is offline
Old 07-09-2016, 06:16 PM
JimB120
JimB120's Avatar
A little help please. I have no green/orange or white/yellow wires in my tail light assembly wiring harness. Can anyone identify the reverse light hot wire from the position in the harness?
JimB120 is offline
Old 07-09-2016, 06:19 PM
JimB120
JimB120's Avatar
Sorry, mine is a 2013 V6 Vert
JimB120 is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
accarter
09-21-2015 11:56 PM
Quick Reply: Tapping into Reverse wiring
