Having some trouble with my heater (when it rains) need help!
Old 10-11-2016, 07:25 PM
CanuckGame
CanuckGame's Avatar
Default Having some trouble with my heater (when it rains) need help!
Hey guys, so a few months back, my thermostat housing cracked, i wish i looked at this forum when that happened as now that im here i see this seems to be a very common issue, and there is even a sticky thread on how to fix it.... geez. anyway i got my car towed to my local Ford dealership, $1000.00 later, it was repaired.
now i notice whenever it rains if i make a turn, i can hear water sloshing, and hissing on the passenger side. and sometimes the water is literally dripping on the passenger floor.... im so confused on whats going on, i moved away from where i got the thermostat housing fixed, so i cant take the car back and ask them to take a look, as its only been happening since they worked on it.
also, the heater, i will crank it on high and when it rains out, it will still work, but it will take 15+ mins for the inside of my car to get warm, usually when its dry out, i will crank it and it works perfectly, warming the inside within 2 minutes.
any help diagnosing the problem is very much appreciated!
thanks
CanuckGame is offline
Old 10-11-2016, 07:59 PM
Moderator
JimC's Avatar
The cowl leak is also a very common problem. Do a search in the S197 section and you will find a lot of threads about it. You need to clean the drain out.
And $1,000 for the thermostat housing? Did they at least give you a kiss and a reach around!
JimC is offline
Old 10-12-2016, 10:24 AM
movielover40
movielover40's Avatar
See if your fusebox on the right side has moisture around it?
movielover40 is offline
Old 10-13-2016, 05:56 PM
CanuckGame
CanuckGame's Avatar
Hey Jim, thanks alot man, this is exactly what was wrong, it was clogged to hell, i cleaned it good and its fixed!
and yes, i couldnt walk straight for a week after i paid that bill, i learned my lesson big time after that.
will259
07-31-2016 05:34 PM
Wellthatsbroken
07-25-2016 01:04 PM
ranger90
07-21-2016 03:35 PM
Magjackpad
07-19-2016 08:53 PM
Quick Reply: Having some trouble with my heater (when it rains) need help!
