Old 10-08-2015, 03:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Specifications & General Maintenance
Print Wikipost
Common 97 Cobra Problems
Old 05-02-2006, 02:54 AM
monkeydude3
monkeydude3's Avatar
Default RE: Common 97 Cobra Problems
yep! which I don't do! and they have a weak point, the shift forks. When i rebuilt mine, they were in perfect shape. one way to avoid damage is not to slam shift when you are bookin, and also (which I will be doing soon) is installing an aftermarket shifter (MGW) that has shift stops so you bash on the shifter stops, not the forks
monkeydude3 is offline
Old 05-02-2006, 03:02 AM
Parsel Tongue
Parsel Tongue's Avatar
re Traction control: My 98 Cobra does not have it - I think it started in 99.
Only traction control on this is to let off
Parsel Tongue is offline
Old 05-02-2006, 03:06 AM
uofipilot
uofipilot's Avatar
Thanks for all the replies. I have read alot on here about the T45 and wasn't sure if thats what the cobras had as well. Like you all have said, it seems to be fine for stock and if you don't WOT shift/beat the living hell out of it. Anyway, thanks again. Your help is appreciated.
Matt
uofipilot is offline
Old 05-02-2006, 03:12 AM
monkeydude3
mine takes a 6000 rpm shift fine so long as I don't hold the accelerator down between shifts... i redline it and chirp 2nd gear with it no problem. Just gotta know not to overshift with a stock shifter or definitely have an aftermarket one
I know a guy at my school who has a cobra like the one you want to get, it is clean!!! sounds mean as heck too
Old 05-08-2006, 04:50 PM
toddlbaker
toddlbaker's Avatar
I just bought a '97 Cobra Convertible with 85k miles and it has an oil leak that appears to be coming from the pan gasket & the CD player doesn't seem to work.
toddlbaker is offline
Old 05-08-2006, 04:52 PM
monkeydude3
okay? the pan gasket will be a pita and i don't know what to tell yo uabout the cd player
Old 05-08-2006, 04:59 PM
HaV
HaV's Avatar
ORIGINAL: toddlbaker
The CD player not coming on at all or it just reading when ever it feels like reading a disk? Its not uncommon in any vehicle nearing or over 10+ years for the CD player to go out... if you swap it for an aftermarket deck (like my sony xplod) you will hear a major difference in sound/quality from it. Its a quick easy swap.. or you can buy a 99 dollar deck at best buy and they will install it free.. either way.
HaV is offline
11-10-2015 11:39 AM
9550
10-26-2015 05:01 PM
09-08-2015 06:25 PM
Sparks_88
09-08-2015 01:06 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Common 97 Cobra Problems
