A/F Guage Install
Old 06-06-2006, 04:17 PM
bsteen81
bsteen81's Avatar
Default A/F Guage Install
Where is the best/easiest place to tap into the O2 signal wire on the car? I have a 98 GT.
bsteen81 is offline
Old 06-06-2006, 04:19 PM
BowlerGT
BowlerGT's Avatar
Default RE: A/F Guage Install
I'll try to help you out because it was a major pain for me to try to find the right wire. If yours is the same as mine (I have a 2000 gt) go on the passanger side kick panal, remove it, unplug the 3 wire harness there and the bracket, then take off the main wire plug with 100+ wires on it. Look for a light grey wire with a light blue stripe on it, peel back the black tape if theres any on there it makes it easier and tap into that there and just put it all back.
BowlerGT is offline
Old 06-06-2006, 04:55 PM
Tac2cul
Tac2cul's Avatar
as said above but alil more details
easy to install
this is all depending on years mines an 01 so this is what i did
remove passenger side kick panel.....there u will see the PCM all the wires connect to it and u have to remove wire loom from the pcm to get in there...
u can connect to any of the front 02 sensor wires coming form the PCM
connect signal wire(usually yellow) to the gry/lt blue wire(#60) on wireloom thats for the right front O2
or
connect signal wire to red/blk(#87) on wireloom and thats for the left front O2
or
run wires all the way out to your O2's in the engine bay(way to much work)
then just find power when key is on and a ground and your set
by the way both wires are next to each other on the connector to the PCM
also i ran power from the traction control wires.....i tried using the defrost button and would get power until the key was all the way forward or something like dat...i forgot
Tac2cul is offline
Old 06-06-2006, 06:31 PM
xx9gt6xx
xx9gt6xx's Avatar
On my 96 I ran the wire under the dash and routed it down the side of the tranny where the shifter is mounted and the wire drops right next to the 02 sensor. Then I just spliced into the signal wire on the 02 sensor and called it a day!
xx9gt6xx is offline
Old 06-07-2006, 01:00 AM
BowlerGT
BowlerGT's Avatar
Either way its a good lightshow to have
BowlerGT is offline
Old 06-07-2006, 02:03 PM
David_K
David_K's Avatar
a narrow band a/f gauge wont tell you anything. you need to get a wideband
David_K is offline
Old 06-07-2006, 04:23 PM
bsteen81
bsteen81's Avatar
Well if a narrow band is worthless, why do they sell them? I dont understand, what is my narrow showing me then?
bsteen81 is offline
Old 06-07-2006, 04:58 PM
blackbetty01
blackbetty01's Avatar
The narrow band gives a very rough estimate, it is fine for normal setups. The wideband only costs about 4 times as much, but it is supposed to be dead on.
blackbetty01 is offline
Old 06-07-2006, 05:06 PM
David_K
David_K's Avatar
a wideband is really only good for tuning and racing but its worth the money
David_K is offline
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
09-10-2015 08:39 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: A/F Guage Install
