questions about my swap
k have a few questions i have a 96 gt switching to pi heads k they say i need a new heater hose for it to fit are they refering to the hose attached to water pump or firewall? and as far as relocating the second sensor from my old intake the new intake looks to have a place that could be tapped that is in the same location as my 96 intake if i have confused any im talking about the air sensor please give me some feedback
RE: questions about my swap
They are talking about the hose that comes out of the back of the water pump that goes to the firewall (aka heater core). The 96 one runs straight down the middle of the valley and the pi intake is plenium is to deep and will not clear it. I got some soft hose and ran it next to the side of the plenium. The cooling sensors are the two front sensors on the intake manifold. On my pi manifold it did not have a place for the second one (right side also that sensor is your engine coolant sensor the left one is the engine coolant sender for the gauge.) so I moved it into the hose that goes out of the water pump does the same thing. If you can find a place in the manifold you could probably tap it but I just got some fittings and spliced into the water pump hose.
jaiidutch
09-14-2015 10:29 AM
