Help w/ winter tire size
Old 06-10-2006, 08:52 PM
ForeverFord
ForeverFord's Avatar
Default Help w/ winter tire size
225/60R16's are 1" taller and I want to put them on this winter . Will they fit PLEASE help if you know. If they won't I know 215/55R16's will but they are just 1/2" taller and I want to get it up higher for snow clerance.
ForeverFord is offline
Old 06-10-2006, 10:27 PM
sprostang
I ♥ Acer
sprostang's Avatar
Default RE: Help w/ winter tire size
Yeah they will fit.
Your speedo will be off though.
sprostang is offline
Old 06-10-2006, 10:53 PM
OnyxCobra
OnyxCobra's Avatar
i personally dont think getting ur stang an inch higher is gonna make a difference when it comes to snow drivng. just get the right size tire and make sure its good in the snow.
OnyxCobra is offline
Old 06-10-2006, 11:38 PM
weasel1088
weasel1088's Avatar
an inch taller is only gonna raise your car 1/2 inch...whats the point?? thats nearly negligable(sp?)
weasel1088 is offline
Old 06-11-2006, 12:08 AM
Fryguy22
Fryguy22's Avatar
check out the Avon Tech M550 A/S tires. They are highly rated. I had them on this winter and my car drove better then my dads 330xi.
Fryguy22 is offline
Old 06-11-2006, 07:37 PM
ForeverFord
If you say they will fit I will give them a shot. Discount Tire said if they don't fit then I can opt for 215/55R16's. And for you other fellas that offered your help ,first every 1/2" your can get your car or truck up off the ground in Michigan for the winter is that much less snow you will be plowing with your front end. And for what is available in sizes 16 and 17 I don't want to buy another set of rims for $500.00 plus bucks just so I can get 17's, when I can get steel rims for $45.00 each w/ 16" rims just to drive thru the winter sense I am going to have to drive my Mustang year round. Thanks guys.
ORIGINAL: sprostang
Yeah they will fit.
Old 06-18-2006, 09:45 PM
ForeverFord
I bought them, tried them, and they did fit perfect just like you said they would, I measured things up and they lifted my car an extra inch off the ground (good for deep snow days). thanks for your advise.
ORIGINAL: sprostang
Yeah they will fit.
Old 06-18-2006, 10:06 PM
sprostang
I ♥ Acer
sprostang's Avatar
See, I told you they would fit.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
aleit2013
09-04-2015 11:58 AM
09-01-2015 08:16 PM
Quick Reply: Help w/ winter tire size
