timing chain cover, need a lil help.
ok i have almost everything off of in front of my timing chain cover, except the oil pump pulley, do i have to remove the oil pump? or is there a way to just pop off the pulley, also in the haynes guide it says i have to pull off the oil pan, it seems a bit excessive. can i just remove the cover without dropping the pan?
RE: timing chain cover, need a lil help.
ORIGINAL: damdanger
ORIGINAL: damdanger
i took the balencer off, thanks on the oil pan, that had me worried, only thing left in my way is the oil pump pulley
ORIGINAL: damdanger
sorry, you seen that before i edited it
watch out the forth bolt sucks take out the bolt you can then the forth bolt take out with a wrench and pull the pymp off a little at a time untill the bolt is completly loose from the cover
KEM Motorworks
08-14-2015 10:13 PM
