Air Silencer
Old 06-20-2006, 10:28 AM
PushinTheLimit
PushinTheLimit's Avatar
Default Air Silencer
I removed the air silencer on my 04 GT and I could tell a good difference. The sticky for that was really good and easy to follow the directions so props for that. I went to go test drive it and it even sounded a little better too along with a better throttle pickup. The only thing I was worried about was that as I was about to park it, it came a flood on me and I was afraid if water was more likely to get in there now that the silencer is off? Comments are welcome.... thanks guys.
PushinTheLimit is offline
Old 06-20-2006, 10:31 AM
Chopper
Chopper's Avatar
Default RE: Air Silencer
Only if you drive through water deep enough to flow in.
Chopper is offline
dstangrunner
dstangrunner's Avatar
Ive had mine off for years. I havent had no problems with water just havin to clean the filter like crazy from dirt.
dstangrunner is offline
Old 06-20-2006, 10:50 AM
PushinTheLimit
That was another question I had too... how often do you have to change the filter now?
Old 06-20-2006, 10:57 AM
dstangrunner
I have a K&N filter so i recharge it every couple of months.
Old 06-20-2006, 11:12 AM
White2000GT
White2000GT's Avatar
If you continue to use a paper filter then I would suggest checking it every time you change your oil. If it is excessively dirty then you should replace it. However, I would suggest going with a high flow filter like K&N. You get better performance with them and when it gets dirty you simply clean it, re oil it and put it back in.
White2000GT is offline
daltron
04-28-2016 08:10 PM
Lethaldosage423
10-19-2015 12:12 AM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Quick Reply: Air Silencer
