Help with possible starter prob.
Old 07-09-2006, 08:26 PM
Zoie_daGT
Zoie_daGT's Avatar
Default Help with possible starter prob.
Well, I am hoping that I can get some help on this one. I was driving home and stopped to get some stuff at the store. When I turned my car on, it kept on cranking as the engine started. It continued for about 10 sec. and then I pulled the key out. Even after I turned the car off, it continued and then stopped. I tried one more time and the same thing happened.
I believe it is the starter but any guesses are much appreciated. Is it safe to drive to my garage about 2 mi. away? Where is the starter located and how hard is it to replace??? As I recall, it is a pain and is up above the tranny. Thank-you for any help.
Zoie_daGT is offline
Old 07-09-2006, 09:50 PM
eternal981
eternal981's Avatar
Default RE: Help with possible starter prob.
could a solenoid be causing that problem instead? if it quits making the sound, i dont see why it'd hurt anything to drive it. might hurt the starter, but even that i doubt.
if its in the same place as the starter in my 2000, its a pain. not really above the transmission. get under the car, look on the passenger side near where the transmission meets the motor. thats where mine is.
eternal981 is offline
Old 07-10-2006, 02:04 PM
Zoie_daGT
Zoie_daGT's Avatar
No one else has done a starter before???? Any takers???
Old 07-10-2006, 02:09 PM
monkeydude3
monkeydude3's Avatar
it is a pain, but if you take your time and have it jacked up nice and high and have a good set of sockets, you can do it. Just disconnect the battery and all will be well
when i rebuilt my trans, I took my starter apart and cleaned and inspected everything and put a little bit of grease on all the bearings, and it made noises before and now it works great
monkeydude3 is offline
Old 07-10-2006, 02:47 PM
Zoie_daGT
Zoie_daGT's Avatar
If I do it myself, I will have it on the lift which is nice. I know that it in theory is easy yet, I thought that it was a pain on the SNs because of clearance issues and such. Looks like it will have to be towed from the store to get it fixed.
Old 07-10-2006, 02:52 PM
mustang_montana
mustang_montana's Avatar
lucky me i had mine replaced during the motorswap. sounds like somethings slipping, definetly just get a new one for 100$ or so.
mustang_montana is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
daytooday
09-01-2015 09:33 AM
Quick Reply: Help with possible starter prob.
