Skilled with the Predator?
Old 07-15-2006, 10:41 PM
sweet99
sweet99's Avatar
Default Skilled with the Predator?
Is it possible to change parameters withoput going thru the whole process again? I wanted to change a few things today and had to go from scratch. Should be a way to go to Modify parameters and pass all of the rest, yes? Perhaps when I plug it in and it gets to the first screen I should hit reset until it gets to parameter reset? I will be adding a set of 4.10's this coming week and would like to just change that. Then is there a way to check what I have set in the tune?
Third how can I log a run with the tuner? I assume the motor has a knock sensor and when it senses knock it retards the timing? That way I can see if I add timing between either the low or higher rpm ranges if I am getting knock if the timing drops off, right? Thanks, mark
PS: I see in the manual there is a section for logging data but how do I get to that screen? When I plug the Predator into the port will datalogging be one of the options I will have available as I did not look for it when installing the tune so maybe it was right there! Yep, answered my own question as diagnostics has the logging option. Just need answers on the first two then, changing a parameter and checking what parameters I have set into the ECM.
sweet99 is offline
dubarado
12-23-2015 01:16 PM
guitarman376
10-11-2015 01:47 AM
Mnuckolls
08-09-2015 08:54 AM
Bowdy04
11-13-2004 01:10 PM
Quick Reply: Skilled with the Predator?
