Drag radials-how low can you go?
Old 08-06-2004, 12:49 AM
RJM02GTDrag
RJM02GTDrag's Avatar
Default Drag radials-how low can you go?
Big race tommorow nite and would really like to perform, weather is supposed to be good for a change. How low can I take the air pressure in the BFG drag radials before they spin on the rim? I have gone to 16 PSI but have heard some guys do go lower, does this affect top trap speed alot?
RJM02GTDrag is offline
Old 08-06-2004, 02:07 AM
callmecobra
callmecobra's Avatar
Default RE: Drag radials-how low can you go?
if you go to low, it will hurt you in the long run. your 60 footer will be better, but once your up and moving, it will slow you down.
callmecobra is offline
Old 08-06-2004, 02:32 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Go as low as you can as long as your tires dont spin on your rim or the sidewalls cup. I've heard of 12 psi on BFG's and 15 psi on Nittos. I go 16 on my Nitto's, never tried lower.
I went from a mid 2.1 to a mid 1.9 dropping from 30psi to 16psi, lost 1 mph but got 3 tenths faster.
mdvaldosta is offline
Old 08-06-2004, 12:53 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
I finally found out how to get good traction on my Daytons. I let the pressure down to about 20psi, get to the line and do a power break from hell, then roll off the line at about 2000rpm. I got a 2.1 in my 60 ft, where before I was at like 2.3 to 2.5. I could never get traction till now.
jdaniel is offline
Old 08-07-2004, 02:08 AM
RJM02GTDrag
2.1 is not considered good traction- you are losing alot on your 1/4 et taking that long to get to 60 foot.
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
TCStangerv6
10-11-2015 05:57 PM
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Drag radials-how low can you go?
