Results from tonight at the track
Old 11-11-2006, 07:45 PM
  #21
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: Results from tonight at the track
ORIGINAL: JD1969
You need a bottle heater.
I need 2 But, as much as I would love to see a juice run, these passes N/A are only getting closer to 11's..
code3GT is offline
Old 11-12-2006, 12:15 AM
  #22
beastzilla02
beastzilla02's Avatar
code how is ur 3300??? with all ur weight reductions and stuff ?? cuz i knowi u dont have any backseats or anything..btw nice times man..must be fun to run early 12's n/a =]
beastzilla02 is offline
Old 11-12-2006, 12:19 AM
  #23
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: 97GT19
New edge Mustangs are heavy pigs
code3GT is offline
Old 11-12-2006, 01:57 AM
  #24
mustangman02232
mustangman02232's Avatar
sounds like you should do 4.30s or maybe even 4.56s
mustangman02232 is offline
Old 11-12-2006, 02:03 AM
  #25
Rusmisel01GT
Rusmisel01GT's Avatar
I also think that 4:30's can only help... what rpms are you at in 4th gear when you let off?
Rusmisel01GT is offline
Old 11-12-2006, 02:04 AM
  #26
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: mustangman02232
I have thought very serious about 4.30's, but I am running about 6K rpms through the traps in 4th with 4.10's. If I do 4.30's, I will get 28" tall rear tires to offset the gear a little. I will see next week how much difference the Meziere water pump and aluminum driveshaft make. I also just ordered a line-lock to give my rear nrakes a rest. I played with the front suspension quite a bit this past weekend, but I think there is still quite a bit more left in the ol' bucket N/A. Will post results and hopefully my bud's Z06 will show up this time.
code3GT is offline
Old 11-12-2006, 02:06 AM
  #27
Rusmisel01GT
Damn, your about peaked out on 4th at the end... might not be able to get 4:30's... When are you getting the shaft/pump installed?
Old 11-12-2006, 02:09 AM
  #28
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: Rusmisel01GT
Yeah, my shift point is 6300. I will have all the goodies installed by next Friday.
code3GT is offline
Old 11-12-2006, 02:13 AM
  #29
snakeman4life
snakeman4life's Avatar
Hell,get some 4.88s or 5.13s and scream that thing to 8 grand[8D]
snakeman4life is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
TCStangerv6
10-11-2015 05:57 PM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Results from tonight at the track
