Need help removing panel around shifter
Old 11-11-2006, 04:37 PM
Shelbyville
Shelbyville's Avatar
Default Need help removing panel around shifter
I have a 2002 GT with a Steeda shifter. I bought an isolator kit to reduce the noice. I just need to remove the panel around the shifter to get at the shifter itself. It looks like the panel just snaps on and off but I did not want to break anything. I have the Ford shop manual but it doesn't help much. It just says remove shifter panel. Yeah, I know. But how. Anyone do this?
Shelbyville is offline
Old 11-11-2006, 05:40 PM
Brady98GT
Brady98GT's Avatar
Default RE: Need help removing panel around shifter
It just snaps. You wont break anything, i've taken mine off a number of times
Brady98GT is offline
Old 11-11-2006, 05:57 PM
StockD15b
StockD15b's Avatar
think of it as if you were a air plane pilot going down.. what would u do PULL UPP. Ya just pull up on it pretty much
StockD15b is offline
Old 11-11-2006, 07:19 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Grab some double stick tape and be ready to chase down some rattles.
Every car I've ever pulled the cover off, it'd rattle after. Double stick tape will solve it.
Dan04COBRA is offline
Old 11-11-2006, 08:42 PM
wwmost
wwmost's Avatar
i remember when i was installing my shifter i was in my car for an hour tryin to figure out how to get that panel of then i just got mad and yanked and it came off fine. dont be scared u wont break anything.
wwmost is offline
Old 11-11-2006, 08:48 PM
Shelbyville
So anger is the key. I was just out in my garage. Hate to be a weenie but this thing won't budge. Is it held in with plastic clips? I yanked and tugged. Does any part of it come out first? Do pry bars help?
Old 11-11-2006, 09:25 PM
MarineNCOIC
MarineNCOIC's Avatar
Try pulling back on the top part first, then sliding it up and out. I will not break anything like everyone said, just man handle it.
Dan04Cobra, where is the best place for the double sided tape. I get creaks when I shift gears as the plastic housing slides around.
MarineNCOIC is offline
Old 11-11-2006, 10:07 PM
dubarado
dubarado's Avatar
ORIGINAL: Shelbyville
get a flat head... and pry it off slowly... you'll hear each *POP* and then it'll be lose... but remember... the 3 switches have cables so don't yank it too hard!!!!!
dubarado is offline
Old 11-11-2006, 10:10 PM
wwmost
wwmost's Avatar
ORIGINAL: dubarado
the t/c defrost and fog switches arent on the shifter panel. its the one above it. the only wires he needs to wory about are the cig lighter
wwmost is offline
Old 11-11-2006, 11:43 PM
Shelbyville
Thanks to all. Its off. Now I know the secret.
jwog666
12-27-2021 08:09 PM
firehorse02
11-16-2015 11:28 AM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Need help removing panel around shifter
